mm12 break in period
Scoop
Scoop Posts: 5
edited November 2004 in Car Subwoofer Talk
right now i have maybe 4 total hrs played,
my gain is set at 0, or the lowest possible, bass control is all the way low, the bass on my headunit is at the lowest setting as well...
it says break it in for 20-30 hrs at moderate volume
should i set my gain to a normal level and just play the sub low? or should i just continue at what im doing now
im afraid setting it to a normal volume will cause too much excursion...
anyone?
Post edited by Scoop on
  • exalted512
    exalted512 Posts: 10,734
    i turned the gain all the way down on the amp and i also had to turn the bass all the way down on my head unit b/c my preouts have such a high voltage
    this way i could play my music loud and not have to worry about blowing em
    -Cody
  • exalted512
    after 20 hours i moved the gain up slightly, just use good judgement, after 30 hours i let 'em loose
    -Cody
  • neomagus00
    neomagus00 Posts: 3,899
    yes! finally! what finally put em over the edge?
  • spwuinmk67
    spwuinmk67 Posts: 797
    Everyone b*tchin about him over in the clubhouse...
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • exalted512
    thank you, thank you
    that and i reported about 5 of his posts to Justin
    -Cody
  • spwuinmk67
    How are you banned and still posting?!:confused:
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • Joelsbass
    Joelsbass Posts: 637
    i'm guessing ronnieboy posted here and they got deleted??
    *starts singing*
    "ding dong the %(^ch is dead....."
    i'm glad that's over......
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • Thom
    Thom Posts: 723
  • max3
    max3 Posts: 44
    Got any recommendation for break in music. I kinda damaged one of my subs playing Nod Your Head Will Smith. Luckily I'm getting a new one so I'll be more carefull with the breaking in.
