mm12 break in period
Scoop
right now i have maybe 4 total hrs played,
my gain is set at 0, or the lowest possible, bass control is all the way low, the bass on my headunit is at the lowest setting as well...
it says break it in for 20-30 hrs at moderate volume
should i set my gain to a normal level and just play the sub low? or should i just continue at what im doing now
im afraid setting it to a normal volume will cause too much excursion...
anyone?
anyone?
Post edited by Scoop on
i turned the gain all the way down on the amp and i also had to turn the bass all the way down on my head unit b/c my preouts have such a high voltage
this way i could play my music loud and not have to worry about blowing em
after 20 hours i moved the gain up slightly, just use good judgement, after 30 hours i let 'em loose
yes! finally! what finally put em over the edge?It's not good, very fundamentally simply not good. - geolemon
Everyone b*tchin about him over in the clubhouse...Originally posted by neomagus00
yes! finally! what finally put em over the edge?1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
thank you, thank youOriginally posted by spwuinmk67
that and i reported about 5 of his posts to Justin
How are you banned and still posting?!
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
i'm guessing ronnieboy posted here and they got deleted??
*starts singing*
"ding dong the %(^ch is dead....."
i'm glad that's over......MacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
Good guess.
Got any recommendation for break in music. I kinda damaged one of my subs playing Nod Your Head Will Smith. Luckily I'm getting a new one so I'll be more carefull with the breaking in.
