Deleted..
Toolfan66
Well ok....
$13.78??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Everybody here knows Larry’s work is top notch. The deleted will definitely takes your SDA’s to a level that is truly special, and well worth the price.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Everybody here knows Larry’s work is top notch. The deleted will definitely takes your SDA’s to a level that is truly special, and well worth the price.
No doubt.
I recently sent him several Tool "board recordings" so I have his address...
I say we all load up, go over there & raid his SDA stash!
Better bring help you'll need it. -
In with 34Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I'll fire up the grill.....who wants hot dogs?
By the way I am located in outer space on another planet, under a very big Magic Mushroom, I can deliver the Deleted telepathically with a special LSD stamp with Mickey Mouse on it for an extra Solar Sun Charge...
Do you charge extra if I use PayPal and request Unicorn Express for delivery.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Do you charge extra if I use PayPal and request Unicorn Express for delivery.
No extra charge as long as it's purple with a rainbow colored horn... -
Russ offering everybody a "hot dog"? Paging Dr. Freud!
Sometimes a cigar is just a cigar. Or in this case, a tube steak.
Three 20 amp circuits. -
Be careful, you don’t know where that cigar has been.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Be careful, you don’t know where that cigar has been.
No kidding probably came from a goat -
Goin deep South here aren't we.
A goat named Monica.
You Sir.....have taken a step away from your comfort zone here. Rock on, Larry...\m/ -
Just post all your bank account information here:
And all your $ will be.....Deleted -
do you still have any of these available? I could use a pair in my guest room, and I would like to buy a set for every member of the Polk forum that is active and in good standing.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
