"headroom" for LSiM?
124»
  • halen
    halen Posts: 712
    edited December 2017
    Hey what did I say.
    Post edited by halen on
    txcoastal1 Posts: 13,503
    Also if you do the AVR biamp scenario make sure to remove the straps on the speaker
  • motorhead43026
    motorhead43026 Posts: 4,008
    Post edited by motorhead43026 on
    – Kevin Alfred Strom
  • BlueFox
    BlueFox Posts: 15,251
    Viking64 wrote: »
    txcoastal1 wrote: »
    And AVR biamping will not improve headroom
    What about moving the seat back and tilting the steering-wheel up?
    At 6’3” I prefer legroom to headroom.
    pitdogg2 Posts: 26,967
    sponger wrote: »
    "And yet at the end of that video they are saying the same thing many here have said over and over and over......."
    He frames that in best case scenario terms when the passives are near perfection and power is derived from "2kw monos." In statistics, those conditions would be called an outlier, thus irrelevant for purposes of general analysis.
    Guess you missed the part where he specifically said on larger top of the line receivers like the Denon because of their larger more robust power supply it makes sense. BUT on all the other lower value receivers it don't make sense to do it because of their power supplies are not as powerful. He then went on to say manufacturers are stuffing more channels on board and not making better power supplies to accommodate these channels.
  • cfrizz
    cfrizz Posts: 13,415
    Guys it's time to let this go, all you are doing is going around in endless circles and getting nowhere!
    You aren't going to convince him and he isn't going to convince you. If his friend ends up blowing one of his tweeters or his receiver, that will be on him.
    Some people simply have to learn the hard way. This is one of those cases.
    Let's move on.
    F1nut Posts: 51,701
    cfrizz, you're a day late.
  • sponger
    sponger Posts: 325
    I mentioned that already. It wouldn't apply to this situation anyway since he most likely would not compare the power supplies in underpowered avrs to those found in outboard amps.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • sponger
    sponger Posts: 325
    cfrizz wrote: »
    The responses from others were that the opposite is true -- that keeping the volume where he currently has it and a little bit higher is perfectly fine.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • ken brydson
    ken brydson Posts: 8,990
    sponger wrote: »
    cfrizz wrote: »
    For a sponge, you don't ....nevermind.
  • dr1978
    dr1978 Posts: 424
    Just make sure your co-worker doesn't hit the pause button on the CD player and crank up the volume just to see where it ends. He seems like the type of guy who would try something like that, and I've learned here that that's a dangerous thing to do.
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
