Slick Deal!
gwh
gwh Posts: 1,451
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
  • dromunds
    dromunds Posts: 10,126
    Dat's sumtin' aina?
  • daddyjt
    daddyjt Posts: 3,080
    Yooooooooou might be a redneck....
    ― Aleksandr Solzhenitsyn
  • decal
    decal Posts: 3,205
    bet that sounds like sheet.
    Toolfan66 Posts: 18,059
    For a garage/shop speaker it’s probably just fine for background music, and it’s a cool project for what it is, and for the person that built it, maybe they have a race car or two but to anyone else I would say it’s junk...
  • Willow
    Willow Posts: 11,231
    Sounds flat...
  • lightman1
    lightman1 Posts: 10,796
    Willow wrote: »
    Sounds flat...
    I think they have a well rounded sound...
  • dkfreebird
    dkfreebird Posts: 1,186
    I think they might wear on you after a while...
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • lightman1
    But they only toe in to the left....
  • dkfreebird
    They can sound unbalanced at times...
    Oppo 103
    Pangea PC
  • lightman1
    You can increase or decrease wedge to get the axis to tighten up.
  • dkfreebird
    They can leave you deflated after long listening sessions.
    Oppo 103
    Pangea PC
  • lightman1
    That's why you have to conserve amp volume to draft all the way to the end of the album.
  • dkfreebird
    Or else they will shred at the end of the album.
    Oppo 103
    Pangea PC
  • dkfreebird
    Or you could use (The clamp) to keep them from wobbling and shredding at the end.
    Oppo 103
    Pangea PC
  • lightman1
    45rpm???? Ohhhh....I thought you said 4500rpm.......splains the hole in the wall from the ejected platter....
    My bad!
  • dkfreebird
    edited December 2017
    Or you could detect a flat spot in the response in the upper frequency.
    Oppo 103
    Pangea PC
  • dkfreebird
    Not trying to rub you the wrong way Russ ;)
    Oppo 103
    Pangea PC
  • lightman1
    dkfreebird wrote: »
    Tradin' paint, Dennis....
  • lightman1
    nbrowser wrote: »
    Well aren't we having a wheelie good time here...
    We were doing so good until this^^^ :s
  • dkfreebird
    Kinda getting burned out on it.
    Oppo 103
    Pangea PC
  • dkfreebird
    Yep, don’t tread on us @nbrowser :o
    Oppo 103
    Pangea PC
  • lightman1
    Got spun on the last lap
  • dkfreebird
    And slammed into the sidewall.
    Oppo 103
    Pangea PC
  • dkfreebird
    Would of never happened if you would of stemmed the tide into the corner.
    Oppo 103
    Pangea PC
  • lightman1
    Ran out of talent on turn four
  • dkfreebird
    We may be loosing traction here fellas.
    Oppo 103
    Pangea PC
  • dkfreebird
    Hydroplaned right across the finish line.
    Oppo 103
    Pangea PC
    EndersShadow Posts: 17,704
    It would go GREAATTTT with THIS!
  • dkfreebird
    Oppo 103
    Pangea PC
