Slick Deal!
gwh
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Dat's sumtin' aina?
Yooooooooou might be a redneck....“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
bet that sounds like sheet.If you can't hear a difference, don't waste your money.
Sounds flat...
I think they might wear on you after a while...2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
But they only toe in to the left....
They can sound unbalanced at times...2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
You can increase or decrease wedge to get the axis to tighten up.
They can leave you deflated after long listening sessions.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
That's why you have to conserve amp volume to draft all the way to the end of the album.
Or else they will shred at the end of the album.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Or you could use (The clamp) to keep them from wobbling and shredding at the end.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
45rpm???? Ohhhh....I thought you said 4500rpm.......splains the hole in the wall from the ejected platter....
My bad! -
Or you could detect a flat spot in the response in the upper frequency.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Not trying to rub you the wrong way Russ
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
dkfreebird wrote: »Not trying to rub you the wrong way Russ
Tradin' paint, Dennis.... -
Well aren't we having a wheelie good time here...
We were doing so good until this^^^
Kinda getting burned out on it.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Yep, don’t tread on us @nbrowser
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Got spun on the last lap
And slammed into the sidewall.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Would of never happened if you would of stemmed the tide into the corner.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Ran out of talent on turn four
We may be loosing traction here fellas.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Hydroplaned right across the finish line.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
It would go GREAATTTT with THIS!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
https://youtu.be/nBp54nQij8s
