Anthem mca325
Hello, buddy of mine pulled the trigger on Mca 325 new to match his anthem avr. He has it on an open shelf and is driving A9’s with the matching centre. When playing at moderate to high levels say -15 , should the amp be so hot you can’t hold your hand on it. Tks for looking.
Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
    Clipdat Posts: 13,087
    Contact Anthem technical support?
  • Their support is really good. At least they have been very helpful to me.
    – Kevin Alfred Strom
  • jimsvm
    jimsvm Posts: 307
    My mistack for not mentioning , it is ultra crisp and clean and blistering loud . My bad. Opps cheers
    Glad the sound is on point, but the running temp would make me a little worried.
    I would take the chassis temperature with an infrared thermometer and then contact Anthem technical support to determine if it is within safe/expected operating temps.
    jimsvm wrote: »
  • DaveHo
    DaveHo Posts: 3,582
    Could be normal. My Aragon amp runs around 125 deg F when up to temp. Perfectly normal given the high bias of the design.
