Nice Creek 5350SE integrated amp w MM phono
Selling my Creek 5350SE integrated amp with MM phono section. The 5350SE is a very highly reviewed integrated that is used as a reference by some reviewers. The amp is in great shape and works as it should. There are a couple of scratches on the top rear of the case. The amp puts out 85 w'ch into 8 ohms and 150 into 4 ohms It is high current capable with MosFet outputs.and a large power supply. The 5350SE has 6 inputs including two tape loops as well as preamp out/power amp in jacks. This 5350SE also has the optional MM phono stage installed which you can see in the picture. Very nice sounding phono stage. It can drive two sets of speakers and has a headphone jack. I should point out that all jacks and the jumpers are gold plated. I have seen a number of these that were not. A preamp gain stage can be added. The 5350SE is built very well and very attractive. This integrated can play with the big boys. The sound is smooth and pretty neutral to slightly warm and sounds way bigger then it is. I do not have the remote but my LT 350 universal. ran it with no issues. Includes, power cord and copy of owners manual. Asking $595 Thanks
