Moving large speakers with spikes
  • lightman1
    lightman1 Posts: 10,797
    txcoastal1 wrote: »
    I go to work, install an electrical box, pop out slugs....priceless :p
    Winner!
  • Unknown
    edited December 2017
    pitdogg2 Posts: 27,255
    90# speakers and soft foam and plastic, just how did you anticipate this would not end as it did? Those spikes worked 100% as they were supposed to, punching through carpet and foam padding to get to the floor underneath.
    ROOKIE ;)
    Post edited by pitdogg2 on
    Tony M Posts: 11,690
    How tall are the spikes ?
    You can probably lay 2 2x4's or 2x3's cut to 15" long. Put them on their 1 1/2" sides on the dolly facing the speakers with them spread till they hit the spikes or just inside of them. There might be a 1/16" clearance on top of the 2x4 or 2x3. The speakers will tilt almost instantly when you tilt the dolly back.
