Can't trust Audiogon?
  • Polkitup2
    Polkitup2 Posts: 1,642
    Noel from Skylan says 25 lbs of rice is the way to go for the hL5+ speakers. I will probably do that since that costs about $8 from Sam's club. Funny, you mentioned vacuum, after I spilled the lead shot I did a final cleanup with a vacuum. Unfortunately, the shot was too heavy to make it all the way to the vacuum cleaner bag, so it now resides somewhere in the vacuum housing. Every time I tun the vacuum on it sounds like a popcorn machine.
    nooshinjohn Posts: 26,062
    Polkitup2 wrote: »
    And spraying lead dust out the vent every time you turn it on. I think I would chuck it and get a new vacuum.
  • Hermitism
    Hermitism Posts: 4,340
    Raw or cooked rice? :lol: Wish I could have gone with $8, lead will probably plummet in price now that I bought some.
  • Hermitism
    You know, when I was a kid, I'd use my molars as pliers to crimp the lead weights to fasten them to the fishing line. I'm probably knocking on death's door about now!
    F1nut Posts: 52,150
    The whole lead poisoning thing has been blown out of portion just like radon gas.
    Noel told me to use kitty litter in my Skylan stands. Instead I used lead shot and sand, way more mass.
  • Hermitism
    Let's not forget the dangers of rice. "Arsenic-laced rice products being reported in the news are not the result of breakfast cereals and baby foods being soaked in poison at the factory. Rather, various natural and man-made processes can cause the toxic element to accumulate in rice grains as they grow." ~thehuffingtonpost
  • Polkitup2
    edited December 2017
    According to a post I saw on the Harbeth forum apparently some users had too much bass energy with sand, so Noel recommended kitty litter. However, some owners still reported too much bass energy. He experimented with some different materials on his Harbeth HL5s and came up with rice as an alternative to sand or kitty litter which he believe provided clearer sound and more articulate bass. His recommendation of rice was specific to the Harbeth HL5. I guess the type of fill that should be used depends on how much damping your speakers need.
    F1nut Posts: 52,150
    Hard to believe one can have too much bass with a speaker rated at 40 Hz +/-3 dB.
  • kharp1
    kharp1 Posts: 3,453
    I didn't want to be the one to verbalize that, but, I agree.
  • kharp1
    kharp1 Posts: 3,453
    Polkitup2 wrote: »
    What type of rice? Brown, long grain, white, instant? Fried or steamed?
  • Polkitup2
    He tested with long grain rice. You want to avoid brown rice because that is oily and will go bad.
  • Polkitup2
    Yea, I would't think bass quantity would be an issue with those specs. Here's the link where it was discussed in post 156:
    http://www.harbeth.co.uk/usergroup/forum/subjective-soundings-your-views-on-audio/electronics-sources-stands-cables-accessories/stands-and-mounting-discussion/94-stands-for-your-harbeths/page11
    F1nut Posts: 52,150
    tmallin's comments are a laugh, reminds me of candyliquor.
    msg Posts: 10,532
    To paraphrase:
    I used to use Skylan stands, but find that Target barstools missing a foot pad each provides just the right amount of wobble give.
  • kharp1
    kharp1 Posts: 3,453
    I sense that the "pint of Guiness" was perhaps the reason for some of the findings.
