The Niles Experiment
I just finished playing The White Album on my new Niles controlled tweeters an do believe I have them dialed in !
You hear the word "forward" in describing speakers and I do believe that's what one might call the SVS Towers............until the other day that is.
I found that magic spot on the third click back from the "normal" setting.
It's like you're getting drawn into the soundstage now.
I found that rather than having to add an equalizer to amplify the mid bass, all I really needed was to give the woofers equal volume by lowering the tweeters output.
I know it's an odd way to accomplish what I was looking for, but there's no denying the grin I get when I listen now.
    mhardy6647 Posts: 35,238
    Is this anything like The Philadelphia Experiment?
    :o
    What you did is called "padding" and it is a time-honored tuning technique.
    http://www.sengpielaudio.com/calculator-Lpad.htm
  • I don't know, unless it happened in the 70's when I was experimenting.
  • I just keeps getting better !
    I decided to see how many clicks back on the Niles that I could go before things started to muddy up and it turned out to be 4.
    3 is the ultimate setting and now I've started to back the sub off too.
    It seems that the 6 1/2" mid woofers were getting buried on either end of the spectrum.
    Steely Dan's "Peg" has a unique synth bass line that has a fuzz type rasp to it which these SVS' never quite delivered.
    By backing down on the sub and increasing the over all volume a bit, it allowed the woofers to show more midrange punch and now I can hear that saw toothed synth.
    Oh yeah, Chris Squire's bass solos stick out a lot better now too !
    Life is good.
  • headrott
    headrott Posts: 5,496
    Polkaguy58 wrote: »
    Life is good.
    One question: Which Chris Squire bass solos are you referring to? The Fish? Or his solo in Nous Somme Du Soleil from Topographic Oceans?
    Viking64 Posts: 7,627
    headrott wrote: »
    I like the Chris Squire isolated bass tracks. :)
    https://www.youtube.com/watch?v=bYvFnkSo6ro
    edited December 2017
    I've always liked those photos of Squire with a ReVox A77, myself.
    (EDIT: And I just noticed the QUAD preamp in the YT splash photo...after all these decades)
    Now, youse guyses want some isolated bass tracks...
    https://youtu.be/YhmImkKvEDo
    (Squire was an inventive bass player as well -- too bad he was stuck with Yes to play for... mostly)
  • The solo that I use for speaker testing is from the song Starship Trooper.
    The very first notes have a lingering tremolo effect that doesn't shine through on an inefficient speaker.
    The bass solo in the middle of the song has a broad note span and will show any frequency drop outs in a poorly designed speaker.
    (The same goes for Neil Pert's descending drum rolls from RUSH)
    There's nothing like the sound of an over driven Rickenbacker bass !
  • Polkaguy58
    Polkaguy58 Posts: 352
    Viking64 wrote: »
    headrott wrote: »
    Those bass tracks were awesome !
    It's funny, as a guitar tech, half my clients would object to the amount of string buzz that Chris was getting off that Ricky..............but hey, if it's good enough for him...........................
