RTi A3s wall mounted as Surrounds
gp4jesus
gp4jesus Posts: 2,019
edited July 2016 in Speakers
My wife found the mounts on-line. (see pics) I have them pointed down at a 40-45 degree angle.
They're rated to 33 pounds. I have about 2" of 2 deck screws in the stud so they're not going anywhere. Yet I can take 'em down in less than 5 minutes. I'm sorry you can't see, hidden behind the grilll, a ledge holding the front. I'll post the make and model when I return.
Before I put them up I took a few minutes to apply Armaflex (poor man's Dynamat) to the mids and closure walls.
Sorry for the mistaken post in subwoofers
Tony
*all connected w/Premiere ICs
  • gp4jesus
    wall mount make & model:
    Cotytech Side Clamping Bookshelf Speaker Wall Mount SP-OS06
  • gp4jesus
    edited July 2016
    Blown away watching "Need for Speed" on cable HD. Never would have guessed the above upgrade plus dropping the surround HP to 80hz (from 90) would make such a big dif!!
  • gp4jesus
    I have mounted my surrounds in my new place. Locating the studs was tough. Seems the carpenter ignored the 16" center to center practice.
    I hafta run power & signal through the crawl space as I have traffic accoss the listening space. Unlike at the old place I could get away w/running both along the RH wall.
    I have to finish moving the last 5-10% out of the old place by May 31st... ...priorities! Then I can do the above.
    Tony
  • gp4jesus
    Miss-posted in my Tri-amped RTi A7 thread:
    Long overdue update (C. July).
    Completed crawl space signal feed & power distribution for surround* channels - mounted same*. Wife LOVES the clean work.
    Added EXO to tweak dedicated surround L&R subs* - added another dimension to my system.
    Since then picked up two MORE of these 27hz gems*, one for each corner taking things up yet another notch.
    Happiness is multiple subs.
  • mikeyb128
    mikeyb128 Posts: 2,885
    edited November 2017
    Dude cut your toe nails! :wink:
    Just kidding man :smile: another audiophile foot sighting.
    2 channel:
    Theater:
  • gp4jesus
    Update: swapped in the same DSP-laden EXO that my LR towers have taking the surround channels up a notch.
  • gp4jesus
    Surprise - ”upgrade” well worth the trouble & expense*! Familiar Blu-rays more enveloping, system more transparent than before.
    *amp for sale soon
    Surrounds driven by a Rotel RB-981. Now all channels’ mids & tweets driven by the same make & model amp. To some, this seems minor, not worth the effort.
    I’ve seen a few on this “write-off” surrounds*. Models from another speaker line or worse, a different brand! I’ll be quick to agree their* power demands are less than the LCR, but they still deserve consideration if you’re not one to compromise.
    To that end,I will buy another 981 and complete actively Bi-amping my surrounds. When I move my system I will add two more 981s to “actively” bi-amped RTi A3s.
    End of Rant
    Happy Thanksgiving Polk Family! Tony
    PS: I don’t understand why everything including my sig is 2X spaced.
  • gp4jesus
    After about 2 months of manual switching I finally automated rear channel “turn-on.”
    The last step was another Furman MP-20. I installed behind the couch. A recently added dedicated 20A* powers it. This* also powers my sub.
  • Geoff4rfc
    Geoff4rfc Posts: 2,930
    A lot of work there. Sounds like it's paid off. I too run a pair of RTiA3's as height surrounds. I've wondered if using mounts and being able to angle them would make a big difference if any at all. So far the performance is enjoyable just having them mounted using the key holes in the rear of the speaker.
    Set up: 11.2 HT + 2ch
  • gp4jesus
    Thanks for the kudos I believe the brackets* are worth the trouble.
    I’ll need another pair* when the “space” is ready. Right now it’s occupied w/kids. Come then I’ll add 2 more channels** and I want matching brackets.
    **I have a pair of ‘A3s and a RB981for power waiting
    As soon as I locate a source* I’ll PM the link
  • Geoff4rfc
    gp4jesus wrote: »
    Dig, I've been searching for another pair of A3's but unable to find any anywhere....
  • ExJAck19
    ExJAck19 Posts: 12
    Here's a set on eBay. Part of me wants to be a greedy **** and buy them, but I've got my free money tied up in redoing my shop's system presently.
    Man Cave: Denon AVR-X2600H, S35, S15 x4, LV12R Shop: Sansui 4000, SDA SRS 2
  • ExJAck19
    ExJAck19 Posts: 12
    Alternatively, here's a set of FXiA6s
    gudnoyez Posts: 8,172
    My rear wall mounted A3s not as a aggressive angle as a 45 degree but they do the trick and I enjoy them as rears over my FXI A6s. Got my Brackets here on the Forum cant remember from whom but a good buy none the less.
  • gp4jesus
    edited August 2023
    These appear near identical to mine, but rated to just 20 lbs. Possibly no drilling or damage to closure finish
    https://store.cablesplususa.com/sp010.html?gclid=Cj0KCQjwi7GnBhDXARIsAFLvH4liJwivu8xs0YL-MO1E5gAJxLQunItekwgZuZUl5QwWDtriu5cYqdkaApkiEALw_wcB
    Cotytech Side Clamping Bookshelf Speaker Wall Mount SP-OS06 came w/a 33 lb rating to safely mount those 16 lb RTi A3s. Per my pictures, a small 2X4 block between the mount & wall, allows for a near 180 degree horizontal swing
    I’ll keep looking.
  • gp4jesus
    edited August 2023
    OOS at the moment but these are the same from seven years ago. Still sold in pairs, & reasonably $d.
    https://www.cotytech.com/speaker-wall-mount-bookshelf-type-side-clamping-sp-os06
    Note: these “clamp” front to rear. IIRC you CAN’T clamp side to side
  • zvucnik
    zvucnik Posts: 55
    looks like brackets are the money, but first need to score set of A3s in cherry finish for my surrounds to match my A7s
