subwoofer carpeting
evhudsons
evhudsons Posts: 1,182
edited February 2014 in Custom Fabrication
Does anyone have suggestions were to get subwoofer enclosure carpeting that would match the carpeting in the car? I'm sure it's fairly standard black or dark grey carpeting.
My car is a Porsche 911 997 if that makes any difference.
Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2013
    I picked up some from a local car audio install shop. It's nearly a perfect match for the light grey carpet in my '95 Trans Am.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Anthony Hinton
    Anthony Hinton Posts: 107
    edited February 2013
    Believe it or not, Wal-mart used to sell some small rolls of auto carpet, they kept it by the steering wheel covers.
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    Fabric store may have some carpet in the color you wish.
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
  • aaronsilver
    aaronsilver Posts: 2
    edited January 2014
    Can you give some details of the fabric stores? It would be very helpful. Thanks in advance.
    Try this website
  • aaronsilver
    edited January 2014
    I didn't get the reply yet. What will be the other works done by the stores? Anybody help. I need it urgently.
    Try this website
  • jhracer3
    jhracer3 Posts: 87
    I've used outdoor type carpet from Lowe's and it matched really well.
  • seabeerob213
    seabeerob213 Posts: 1,843
    try joannes fabrics, or walmart, or a car stereo shop
  • [Deleted User]
    Just find an automotive interior shop in your area. Company called Ozite offers just about every color and texture to match OEM carpets and trunk liners.
  • ken brydson
    ken brydson Posts: 9,095
    Slapaho wrote: »
    Holy necropost Batman.
  • lightman1
    lightman1 Posts: 10,801
    Slapaho wrote: »
    Post T-day drinkin' will bring these up from the dead on occasion.
    msg Posts: 10,626
    So does a US Robotics 14.4k.
  • DaveHo
    DaveHo Posts: 3,584
    As long as the carpet matches the curtains, you're golden...
  • BlueFox
    BlueFox Posts: 15,250
    Lightweights. The full duplex Vadic 1200 bps is tops, and was invented by them. Four times as fast as the previous 300 bps modems at the time. Testing/fixing Vadic modems was my first job in CA when I moved here in 76. Computer networking has been a good career for me. :)
  • VSAT88
    VSAT88 Posts: 1,383
    This dude that I know owned a used car dealership. He told me he would pull the carpet out of cars, shampoo it, dry it and then spray it with spray paint. Wonder if black spray paint would do ? (Tee Hee)
