thoughts
Opinions please....Which sub would do justice in a HT/MUSIC system with bookies. My subwoofer experience is lacking these days. Don't throw out SVS as they are out of the ballpark.
Velo cht-10
Paradigm ps1000
Dayton 1200
    txcoastal1 Posts: 13,513
    I used to own a Velodyne
    The front firing CHt-10 would be my vote
  • hochpt21
    hochpt21 Posts: 5,423
    How big is the space?
  • gmcman
    gmcman Posts: 1,849
    I have had this sub for quite some time but I really enjoyed my Mirage FRX-S10 when I had the RT800's as my main speakers. Not boomy at all and paired well for music. Also had plenty of punch for HT when properly placed.
    tonyb Posts: 33,072
    hochpt21 wrote: »
    24 by 26....hence my concern on too small a sub. Larger sized sub and less watts, or smaller sub with bigger power Like a Def tech or Sunfire JR.
    The Velo cht-10 I'm pretty sure would do fine for music, the HT side though, it may have trouble in a room that big.
    Agree, wasn't thinking HT, just a little umph for 2chnl
  • daddyjt
    daddyjt Posts: 3,085
    If it's one sub for everything, I would go smaller sub with more power every time. Of the options you listed, I'd do the CHT-10. What's your budget?
    ― Aleksandr Solzhenitsyn
  • hochpt21
    edited November 2017
    Black Friday Deal..
    tonyb Posts: 33,072
    All the subs I mentioned can be had for around 100 bucks, I can go 200 maybe. Which is why I said SVS is out.
    Also saw a Mirage ps-12-90, which gets good reviews but I'm skeptical of bigger woofers and weak power, spells muddy bass notes to me.
    tonyb Posts: 33,072
    I'll look around Ken, thanks for the suggestion.
    tonyb Posts: 33,072
    This one came up, but Def tech subs are usually either people love 'em or hate 'em.
    https://chicago.craigslist.org/nwc/ele/d/definitive-technology/6398192822.html
    The Piano Black would match the speakers though.
    msg Posts: 10,452
    I have the smaller SC3 in the home office. Pretty amazing for its size, but the room's just 11ft square. I just checked to see what level it's at - around 1pm on the volume knob, so, pushing it a bit. Put me in the love-it camp.
    SC2 would be even better, and I think it was not affected by the amp issues the SC3 had.
    Got any used HSUs in the area?
    The STF-2 might be an available good bang-for-buck. Doesn't have the extra tuning options of the higher level series subs, and may be a little loose for you, but it can pressurize an 11x15 space with room to spare at just the 10 o'clock volume position.
    Coupla thoughts.
  • deronb1
    deronb1 Posts: 5,021
    Maybe look for a used Velo Impact 12? Good reviews for both music and HT.
    nooshinjohn Posts: 25,926
    How about a REL T5... the high level input allows for seamless blending to whatever speaker you are using. I have the S5 and love it.
    tonyb Posts: 33,072
    Think older subs John, a Rel T-5 for 200 bucks would be a find.
    I found one for under 400... :p
    There are a couple Q108’s on EBay now under 200 bucks.
    Also a Klipche r10sw in Napierville
    tonyb Posts: 33,072
    That ones on my list Skip thanks.
  • daddyjt
    If you can find an RSW10D, that's a find. That sub is STOUT. Make sure it's the "D" model. They go for around $300 used...
    The one I found was listed at 250.00
    tonyb Posts: 33,072
    DSkip wrote: »
    Honestly Tony, the Chicago market is ripe with flipping potential. Might not be a bad time to play that market if you can. Craigslist right now is where the DFW list was about 4 years ago. Everything has dried up in these parts.
    Indeed it is Skip, I'm looking for direction from sub users so I can weed out the sloppy/slow or muddy sounding ones.
    The criteria is,
    Movie /music use
    Room size of 24 by 26
    Smaller size due to placement issues.
    .....and of course budget around 200...maybe 3 if I push it some.
    tonyb wrote: »
    There is a REL T5 on Audiogon for 195.00 B)
  • rooftop59
    rooftop59 Posts: 8,121
    tonyb wrote: »
    While that is a very nice deal and would make a great office or bedroom sub, it is TINY and -6db@32, not exactly what @tonyb is looking for to fill his large room. Someone else, however, might want to jump on this deal!
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,072
    Already got a sub gents, an SVS SB-2000, which is working out beautifully.
