Phono pre hum
    mhardy6647 Posts: 35,020
    edited November 2017
    Probably worth noting that figuring out what to ground to what generally has to be determined empirically in cases like these. :)
    Also, perhaps, worthy of note. My Marantz (Clearaudio) TT-15S1 came with two ground leads -- one for the tt proper (connected, I suppose, to the platter mount) and the other to the (detached) motor.
    As I intoned, oh so gravely, earlier: grounding is both art & science :|
  • jdjohn
    jdjohn Posts: 3,357
    And trial and error :D Glad Bob is sorted. Another good reason to keep a few spare wires around.
    Mark my words:
    Bag o' clipleads.
    1001 uses!
    Collect 'em, trade 'em, give 'em to your friends!
    They make great stocking stuffers, too!
  • lightman1
    lightman1 Posts: 10,796
    Hardy-ed up another thread....
    msg Posts: 10,452
    Hey, look who it is!
    lightman1 wrote: »
    I'm here for youse guyses.
    Think of me as Johnny Clipleadseed.
    I should keep little gift bags of 'em here at the ol' casa.
    This could be you! (borrowed images, no warranty express or implied. Always keep one hand in your pocket when working with HV.)
    pitdogg2 Posts: 27,054
    Man those pictures just scream FIRE B):*
    msg Posts: 10,452
    To me, that bottom one screams, "Ouch Ouch! Hot! Ahh! My fingers!"
    Viking64 Posts: 7,556
    I have no idea what any of that is.
    Amplifier breadboards of various flavors.
    msg Posts: 10,452
    I like my breadboards toasted and flavored with Vegemite.
  • muncybob
    muncybob Posts: 3,240
    It might make a difference if it is only 'asleep'.
    If you get bored some time, try unplugging the player from the AC mains and see if it changes the noise signature on your phono preamp any.
    So I was curious to see if this made any difference...it did not. I also tried other areas to ground and still no improvement over the Oppo ground. The power strip itself(Panamax M4300-EX) has a ground lug so I made another ground wire(now up to 3) and no difference. So, this is as good as it will get and that's fine. Thanks again for all the help, tunes are sounding much better :)
    Yep, my name really is Bob.
    Yeah, so your hum/noise is due to circuit &/or power supply, it seems.
    One other thing you could try if you get really, really bored (and if you haven't) is to either open circuit the inputs (no cables installed) or (probably better short the inputs (shorting plugs or cables with both leads connected together) and see what the "absolute" noise level of the preamp is. Shorting the inputs would isolate the preamp pretty well, such that any noise you hear is from the preamp (or - it is still possible - being induced into it from external EMI sources).
    High gain vacuum tube circuits have a tendency to be noisy. Even solid state circuits aren't immune from the hiss of "shot noise" at high gain.
    I will close by mentioning that even I ultimately settled on a (gasp!) solid state phono preamp at my house. :|
    (legacy photo of an experiment with the aforementioned ss phono preamp & Silk SUTs -- and plenty of clipleads!)
  • lightman1
    Doc...you're gonna burn your house down one day.....Safety First! :p
    Point taken, your being a pro & all... but, in my defense, everything there is low voltage DC (well, other than the audio signals, which are AC on the order of 100s of microvolts on the "innie" side & a volt or so on the outie side).
  • FestYboy
    FestYboy Posts: 3,861
    Wow, an "innie" AND an "outie" @mhardy6647 you must be proud :p
