Used McCormack DNA-1 vs Parasound A21
Any recommendations on either amp? DNA-1 is stock.
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • MrBuhlMrBuhl Posts: 2,308
    DNA-1 all day long for me, though to be honest, I have no experience with the Parasound directly. I have a DNA-1 and a DNA-0.5 and love them both!
    VA 2 Channel ,Dodd 50W Dual Mono EL34 Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, Audioengine B1, MIT AVt3 Speaker & RCA Cables, PS Audio Power Punch power cables
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
  • StevieBStevieB Posts: 232
    MrBuhl wrote: »
    I've got the A23 now and was looking to upgrade. Thanks for your thoughts.
  • tonybtonyb Posts: 30,169
    DNA all day for me too.
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
    It's muscular, and detailed without being fatiguing IMO. Gobs of reserve power to control the low end in ways I have not experienced before.
    It actually doubles as the load changes 150w into 8ohms, 300w into 4ohms, and a whopping 500w into 2ohms. I don't often see amps in this price range list a 2ohm stable rating.
    Not that power is everything, it's not. I have had amps that get close to those ratings at least at 8 & 4 ... but more because this amp "sounds" beautiful to me as well - I can't really explain it, but it's the best sounding amp I have ever owned.
    Polk SDA1c modded
    Yamaha YP-D6
  • kharp1kharp1 Posts: 2,587
    Have had both and the DNA hands down.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
    Pulled the trigger on the DNA-1, very nice so far driving the 3.1'S! The ability to upgrade it is intriguing as well.
Howdy, Stranger!
