Calibration
jeremie
jeremie Posts: 246
edited November 2017 in The Clubhouse
So I had my theater calibrated, the bad news is that I am going to need a new projector soon :) due to colors not adjusting well. All I can say is the lsim speakers rock now. I used Yamaha’s ypao setup and it said I had speakers out of phase, speakers distances were off as much as 3ft, boosted higher frequencies and so on. Much happier now. If anyone is looking for a professional contact Jeff at https://www.accucalav.com. He travels all over the US and has done over 2000 systems. Main things he said would help my room is to change the fabric on my acoustic panels as they are deflecting some higher frequencies and add a few more and paint my walls and ceiling darker. Too much light reflection.
Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
  • Your room sounds like mine. I definitely want to paint the HT ceiling black. YPAO says my RTI12’s are reversed. Looks like there pointing the right way to me.
  • Willow
    Willow Posts: 11,246
    Oh no you didn't... just say that, did you?
  • Sorry... meant they’re not there.
  • gp4jesus
    gp4jesus Posts: 2,019
    I don't follow you...
    *all connected w/Premiere ICs
  • mdaudioguy
    mdaudioguy Posts: 5,164
    gp4jesus wrote: »
    He was correcting his spelling in the post before that - "they’re" not "there."
  • gp4jesus
    Reversed? As in reversed polarity?
  • gp4jesus
    Willow wrote: »
    what is "that?"
  • FestYboy
    FestYboy Posts: 3,861
    "that" inferring that you assumed that YPAO thinks the speakers are facing the wall instead of being out of phase which is what it means by "reversed".
    pitdogg2 Posts: 27,200
    YPAO see them as out of phase. Seems to be common with Yamaha YPAO.
