Marantz sr-6011.....Polk S60.......can I use 4 channels to power 2 towers?
MackMurder
MackMurder Posts: 27
Ok so the marantz 9.2 channel amp has like 110 wrms @8 ohms per channel
I know the S60s can be bi-wired or bi-amped
Bi amp means more power from 2 different amps. Adds better sound and more detailed?
My question is could I use two front channels for the lows and 2 surround channels for the highs? For a total of 220 wrms per tower? Or will that **** up my amp.and or speakers
Home theater:
-Samsung 65" Q7F Qled - XboxOneX
-Marantz 9.2 Channel SR6011
-Tech 1200's
-Polk S60 Towers
Car Audio:
-4500 wrms cresendo mono block amp
-Fi SP4 v2 18" sub (3000 wrms)
-hertz 1000watt 4 channel
-hertz mille component speakers
-hertz spl 10" 600 wrms sub
-370amp mechman alternator
-2xs power 3300 amp batteries
-2/0 gauge ofc everything
    F1nut Posts: 51,973
    It doesn't work like that. You cannot bi-amp from a piece of audio gear that has a single shared power supply as does every AVR made. Pure marketing hype.....otherwise known as BS.
  • awsome thanks F1. Bi wiring would be the option for me tho correct? With some good wire as opposed to the stock material Polk provides?
    Home theater:
    -Tech 1200's
    -Polk S60 Towers
    Car Audio:
  • rpf65
    rpf65 Posts: 2,127
    Bi-wiring, running 2 sets of cables, from 2 different out puts, to each individual's binding post on your speakers, can be done with most AVR's. Most people hear no difference from using this method or a single cable run.
    More people hear a difference when they remove the factory jumpers and replace it with jumpers made with good quality wire.
  • rooftop59
    rooftop59 Posts: 8,120
    rpf65 wrote: »
    Yes, just do this. Ideally try to make he jumpers from the same wire as the cable. Blue jeans cable has some nice affordable options.
    Game Room 5.1.4:
    Bedroom 2.1
  • Done and done
    Home theater:
    -Tech 1200's
    -Polk S60 Towers
    Car Audio:
