Polk Audio DSW MicroPRO™ 4000 blown amp
My sub has been out of commission for quite some time. I took it to a repair shop and after a few weeks of diagnosis they said the problem is in a proprietary board. Polk no longer sells replacement plate amps. Is the Dayton Audio SPA1000 a viable replacement or should I cut my losses and move to another sub? If I should move on, what is a good sub around the $500 mark?
  • Wow thanks for the awesome help. I'll go pick up my sub and see if the SPA-1000 fits.
    Yes i can bump my budget. Would the HSU be better than the PB-1000? Out of the three options, which is the best?
  • rooftop59
    rooftop59 Posts: 8,120
    edited October 2017
    Considering the cost of the Dayton amp and the fact that it may not sound the same after, I would get the HSU. The better of the two new options...and this is from someone who has owned both hsu and svs.
    Game Room 5.1.4:
    Bedroom 2.1
  • VanillaXtract
    VanillaXtract Posts: 4
    edited October 2017
    That works for me. Is the HSU a big step down from the DSW4000? What would a comparable sub cost?
  • rooftop59
    No, I don’t think it’s a big step down. In some ways the HSU is better. It will go deeper and playlouder, it doesn’t have quite is much tech built it, and the sealed micropro MIGHT be a little tighter sounding.
    The main thing you are paying for with the micropro is size and Best Buy. It takes money to get that much out of such a small box, and it takes money to sell at brick and mortar stores.
    Overall I think the HSU is likely the better all around, but the micropro might be slightly better for a 2 channel system...
    Game Room 5.1.4:
    Bedroom 2.1
  • Splendid. I bought it used off a friend for $500 a few years ago, so I am feeling I got my money's worth out of it. I will go ahead and order the HSU. Thanks again for your help.
