Golden Tube Audio SE-40 - Good for SDA-SRS or 1Cs?
audio_alan
Hey guys, I have a quick question about the GTA SE-40:
1) Is the SE-40 a common ground amp suitable to use with SDAs? (I searched, but couldn't find an answer).
2) Will they be powerful enough to run my original SDA-SRS speakers? If not, how about 1Cs?
Thanks!
-- Audio Alan
Thanks!
-- Audio Alan
I don't know if it is common ground. If it is, it might do ok with the 1C's, but barely. It will not work well with the SRS.
President of Club Polk -
Thanks, F1. I had a hunch it wouldn't be enough for the SRS's. I think I'll just pass on it, especially if it's questionable about being common ground...
It's a pretty cool looking amp though, so I was tempted. -
Not to spread misinformation (me?!? ) but weren't these GTA amps rather notorious for their fragility? Maybe I am thinking of a different model...
It's a pp EL34 amplifier, isn't it? Something like 35 watts per channel, give or take (maybe 40 or even 50) -- kind of hard to imagine that would be optimal for any of the SDAs (although I have zero data on this myself!).
mhardy - I think it's a Class A 40 watt/ch amp, and yes, they were known for having a lot of breakdowns. It doesn't have EL34's in it.
The guy selling the particular amp I was looking at says to have refreshed all the components, so it shouldn't have those reliability problems. I'm still debating picking it up to run with some smaller speakers. But, I do most of my listening on my SDA-SRS system, so (as F1 pointed out), it would be severely underpowered. -
I may be wrong, but I think that amplifier runs its tubes hard -- in other words, the fragility is intrinsic.
What are the output tubes? 40 watts in Class A would take pretty massive high voltage and beefy output tubes.
Still trying to find info on the design; here's a "review" of sorts from audio asylum.
https://www.audioasylum.com/messages/amp/145165/review-golden-tube-audio-se-40-amplifier-tube
EDIT: well, ok, maybe mainly crummy parts (i.e., in the original, new production models): http://audiokarma.org/forums/index.php?threads/golden-tube-audio-se-40-amplifiers-love-em.308083/#post-10470500
http://forums.stevehoffman.tv/threads/opinions-on-the-golden-tube-se40.22321/
EDIT^2: aaaaaah. three paralleled 6L6 outputs 40 watts... hmmm...?
Sounds like you answered your own questions, mhardy.
Agreed, it sounds like the parts were just sub-par and undersized. I'm still tempted, but might just look for something else with a better reputation...
