Curbside Rescue Project
xschop
I made a another set of the billet feet for a curbside find I'm about to customize.
Its a Kenwood KR-V6020 and the only thing I could find wrong with it was a broken headphone plug in the port....and 2 missing feet... After removing the plug with a fine set of needle nose pliers and checking the DC-offset per Audiokarma instructions, it works perfectly. I did De-Oxit all the controls...
This faceplate is 1-piece anodized aluminum that I will make into a fine/brushed look and rehone some skills before I do this to a brand new onkyo CD player....
Nice feet!
PS:
I'd have picked it up, too!
i.e., you're as bad as I am ...
repent, repent! While there's still time...
Free education as I've already learned Kenwood's methodology to their faceplate anodizing. Pleasantly surprised that the control signage is countersunk.
I'll be doing another 15% CaOH bath. The center indention strip had a good buildup.
Don't take experimental gene therapies from known eugenicists. -
It's kind of impressively amazing that this piece had an aluminum faceplate (as opposed to gen-u-ine plastic made to resemble anodized aluminum)!
And surprisingly a high quality alloy with no galvanic pitting. Makes my work much easier.
The signage must be laser etched before the 2- step anodizing took place. I could easily polish this alloy to a mirror finish but it would ruin/elimimate the countersunk lettering....
After 320 grit wet sand. I like the look.
I did the final polishing with a plastic polymer scrub pad....
Planning on a contrast for the laser etching?
No, just the incognito look is appealing. I hope the Onkyo lettering is the same, but I'm not holding my breath.
Looking more closely at the innards, they're all Elna caps...and no bulging tops.Don't take experimental gene therapies from known eugenicists. -
That's one way to get a silver faceplate.....I like it!Political Correctness'.........defined
President of Club Polk -
F1, Thanks to you, a couple of my pieces have now been accosted by the butyl mat treatment. It really does stop the resonances and adds a solid feeling to the sheet metal. Also, you can never have enough bling...
Even if you wont see it....
Accosted......that's a trigger word, I'm offended.
Somehow I find that statement difficult to digest.Don't take experimental gene therapies from known eugenicists.
I was gonna buy a new amp to push my Cerwin-Vegas, but it accosted to much.
I also find it difficult to fathom that Mhardy owns Cerwin Vegas as well.
I was going to machine a billet volume knob, but realized there is an LED indicator I don't want to cover. I did make a billet phone plug with enough OD to just barely cover the faceplate...
The real bonus is my G4 cellphone remote app controls this guy....Im just a tad elated...
I wuz bein' facetious
but, that said -- actually, there are a pair of C-Vs here. They were given to us by some good friends and they served my son well in his high school years. They're just -- umm -- somewhere down in the basement at this point.
Come to think of it, they were my first woofer refoaming experience
Even went for the C-V red surrounds.
I do have to say (back on topic), the faceplate looks wonderful, but the knobs just aren't quite doing it for me...
Just jesting myself. You're into horns, not knobs lol.Don't take experimental gene therapies from known eugenicists.
Horns....knobs, more trigger words. I'm telling.....ummmm, well someone.Political Correctness'.........defined
Maybe some "High" yellow silk screened words would help.
Looks like this was one of the better CD players from this era (DP-8020). I'll keep an eye out for one and make it match the receiver....
Nbrowser, I prefer the more subtle approach by offering the offended party a nice side of cheese and crackers.... to go with all that whine.Don't take experimental gene therapies from known eugenicists.
Who said anything about feelings? I thought F1 was a bot.Don't take experimental gene therapies from known eugenicists.
So he lives in his 1.3's... Now I understand hehe.
He's a good sport. Funny too.
I admire his uncanny ability to convey, ever so gingerly, that your project/modification is or will be a spectacular fail.Don't take experimental gene therapies from known eugenicists. -
First time setting idle adjustment...
I found the service manual and it states to adjust idle current to 10mV for L-R channels.
Upon initial reading both channels showed 4.5mV... Is this normal to be out of spec this far? And does changing/adjusting idle current change DC offset to where I'd have to recheck it at speaker terminals?
