Amps-leave on all the time
bignorm
Just purchased a NEW NAD 925THX amp
Should I just leave it on all the time or turn it off after use..
It will used daily 4-6 hours....
Eliab/Dave Abrams calibrated Panny
Yamaha,Denon,Toshiba "in the rack"
Polks all around
SVS on the floor
Polks all around
SVS on the floor
Post edited by bignorm on
why would you leave it on for 15 + hours not being used? I turn all my gear off..
wow you use your gear for 6-8 hours a day?
Its all personal preference, some say its better to leave it on, some don't.. I don't leave my car idle all night though so i dunno
We just had a thread on this, do a search....MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I leave my stuff on.
SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
OffCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I turn all mine off when not in use. (provided I don't plan to use it in the next hour or so)
Electronic equipment, although having a long life span, does have a life span. To be safe, I would shut off the equipment to make sure the thing lasts the entire time you want it to.Brian Knauss
ex-Electrical Engineer for Polk -
OK THANKS!!!
I tried to do a couple of searches....but didn't know what to key on to start the search
I will probably shut everything down after use.......
Thanks again!!;) :rolleyes:
Polks all around
SVS on the floor -
Turn it off Bignorm. Don't use the electricity or run you gear unless you are using it.:DMain Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
Personally, I leave most everything on. I do have the Outlaw mblock I have set to turn off automatically. But my Crest Audio does not have that feature or a remote. So to turn it on, I have to get my lazy butt up off the couch
If I turn off/on my pre-pro (AVR), it causes a loud pop occasionly which is not good.
So, I just don't deal with it and leave it on.
Regarding opinions I've heard about leaving electronics on, supposedly if you turn them off and on they heat up and cool down and thus expand and contract. Over time I've heard the various circuits could loosen their connections via this process. Whether or not that is true, I don't know. If the piece of electronics has a fan, the downside to leaving it on is the fan could prematurely wear out.
I agree with faster100 said, personal pref.
