anyone have stashed pre amplifier w/ remote
Now I'm using a NAD 1020a which does everything aI need w/ the exception of a working remote. This unit not remote compatible. Requirements are Phono stage, tuner in, and either dedicated cd or aux to do the same thing. Getting lazy in my old years and would like a working remote to change inputs.
The pres already in and out of my stable are
1. Onkyo P-301--w/remote---SOLD
2. Onkyo p3150v--w/remote---Monter Cble Grip 'o death pulled out outputs--dumped
3. Sony ESD-2000 sound processor overly complicated but had pre/outs to convert to pre/amp---w/remote----SOLD
4. Dynaco Pat 4--Lousy phono stage no remote---sold
5. Present day--NAD 1020a again not remote compatible.--still here
So forumites any ides and as you know I'm one poor due,wa wa wa wa.So price is an issue.
Prize piece Parasound P-5 But out of my wallet range by miles .....Lew
What I need is a generous benefactor...
  • DollarDave
    DollarDave Posts: 2,575
    edited September 2017
    $200 + shipping will get you my extra Yamaha a-s501integrated with remote. Nearly new.
    Add a chromecast Audio $35, connect to the integrated dac and your good to go.
  • I have a Sherbourn Pre-1 with the remote that has about 50-75 hours on it. It doesn't have the bass management that the earlier ones did. It's in like new condition.
    Has balanced and RCA outs. $200.00 + shipping. I upgraded to a P-5.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    gudnoyez Posts: 8,172
    A mint Adcom GTP 450 with remote no phono preamp $125 shipped, have others but no remote.
  • DollarDave
    DollarDave wrote: »
    Includes phono input, digital inputs, subout, stylish Yamaha looks, and 4ohm stable.
  • Upstatemax
    Upstatemax Posts: 2,775
    TNTsTunes wrote: »
    Glad to see that you seem to be liking the P5!
  • Airplay355
    Airplay355 Posts: 4,298
    I've got an AMC pre. Has a phono stage but no remote. It's just hanging out in the closet. I used it for a bit when my receiver kicked the bucket and I waited for a new pre.
    Anyway, $75 and we can split shipping. If you're interested PM me.
  • so is the NAD 1020a going up for sale then? :*
  • leftwinger57
    leftwinger57 Posts: 2,917
    No, the 1020a is so good I would keep it as back up. The Yamaha I will look into. It seems the earlier pres did not have remotes until the later Onkyo P models and all the other Japanese examples. How do they compare lets say w/ an APT-Holman and others of that vintage w/ the newer ones w/ remotes. I found that the weak link to the Onkyos was their amp output female jacks that loosened over time. Again guys don't bother w/ pres that do not have a tt input.
    That's a tall order in a pre on the cheap Lew. You might have to prioritize your needs. Separate phono pre's are cheap these days and it may be better to acquire a pre without one and simply add a separate phone pre to it.
    Then again, I have to ask....why are you spinning vinyl still anyway ? If your trying to do things on the cheap, cheap and vinyl don't belong in the same sentence.
    Digitalize those albums, put them in a lossless format on the computer/hard drive and stream them to a dac/pre. Depending on what you use to stream, you'd have a remote in the palm of your hands to control and access all your music. The pre wouldn't even need a volume remote.
    To me anyway, and considering your knee problems, budget concerns, digital is right up your alley to simplify things.
    mhardy6647 Posts: 35,180
    edited November 2017
    Cheap basic preamp with remote = Kenwood KC-206.
    The trick is to find one with its remote (BTDT). :blush:
    There are said to be smartphone apps to emulate the KC-206 remote.
    Without a working remote (of some sort), the KC-206 is essentially a brick :/
    (borrowed photo -- the one that passed through here was sans remote)
  • Tony, Oh no I BUY WHEN i can either garage sale $1 bargains or get still in the shrink and brand new. .
    I dunno Lew, a Chromecast 2 can be had on ebay for 15 bucks, providing that's not a budget buster. ;)
  • TNTsTunes, do you still have that Sherbourn Audio Pre-1? Thanks.
