Speaker set up options/advice
I have an abundance of speakers and looking for the best quality set up/configuration
Denon s900w
Speaker options
Polk Monitor 60
Polk Monitor 70
Polk r300
Center
Rm 202
Cs1
Satellites
(4) Rm101
I have a boson acoustic splitter so I was going to run the two monitors off my “front” the cs1 and then 4 satellites just looking for some experienced input. Thanks in advance
Phil
  • Easy Runnin
    70s front, 60s surround, CS1 center.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • Easy Runnin
    Get a sub
  • phil1369
    Oh I have psw10 and actually an old velodyne vrp-10 was thinking dual subs not needed everything else is Polk
    Do you think 60s should be surround front or back then I’m guessing just use 101s As other and thank you for input it’s just getting be a lot
    I can always count on dead fans thankfully
