Common Ground Amps
riglehart
riglehart Posts: 276
edited December 2006 in Vintage Speakers
I have an NAD2200, which I was told on this forum isn't common ground. So, I built an AI-1. The NAD is solid, but I'd like to go back to the plain cable. You loose something with the transformer.
From what I can tell, wheather an amp is common ground or not is never published. Does anyone know if the other NAD amps 2600, 2700, 2400, c270, etc.. are common ground? I'm worried it might be a design feature of NAD in all their amps.
Are 99.9% of the amps out there common ground? Or is non-common ground fairly common. (no pun intended)
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
  • amulford
    amulford Posts: 5,020
    edited November 2006
    A large majority are common ground. I even have a "dual mono" that is common ground. Usually I check with the manufacturer if I have any doubts.
    Onething to think about is brigdeabilty. Normally if you can bridge it, it's common ground.
    FWIW, I know the NAD 2700 is, I have one.
  • Emlyn
    Emlyn Posts: 4,888
    Most two channel amps are common ground. From what I've seen, those that are not common ground often have a statement on the back of the amp or in the user manual saying something like "This is a balanced amplifier, do not connect to ground" which is usually there to alert people to potential problems with speaker switching devices rather than SDA's. This doesn't apply to all amplifiers though, so the first thing to do as said above is to check with the manufacturer's customer service line, and once you get an amp (even despite being told it is common ground) check the speaker terminals for continuity yourself with a meter to be sure it's working as designed. It's simple to do and potentially saves blowing something up.
  • hearingimpared
    hearingimpared Posts: 21,136
    If you bridge two NAD 2200 mono they are not common ground. A single NAD 2200 in stereo mode, the grounds to the speakers are common. Take a VOM and measure (with the power off, unplugged would be better, with the speakers disconnected) from the ground of the right channel post to the left ground of the left channel post, you will find the reading is zero ohms.
  • univera
    univera Posts: 848
    Why not buy my 2200 PE and bi-amp your Polks...
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • hearingimpared
    I could be wrong here. I used 2200 on SRSs in the late 80s. I don't remember having any problems with them used as a single amp in stereo mode. I ran into problems when I used two bridged mono, one for the left and one for the right channels.
    I read through NADs literature on the 2200 and don't see anything about non-common ground on a single stereo amp.
    Here is the pdf of the 2200 manual.
    The only thing I see about a difference in signal is the section entitled, "Inverted Channel for Powerful Bass." I think the best thing to do is to call NAD and check with them.
    If I am wrong I apologize for the misinformation.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Thats not always true. If it has a bridge switch it is most likely common ground. If it is the style(like a car amp) where you hook the the speaker up to the left pos and the right neg (or vice versa) the it more than likely is not. In this style of amp the left pos would be the hot, and the right neg would be hot also, but inverted.
  • amulford
    Which is why I say to check with the people who made it if you have any question...
  • dudeinaroom
    exactly
  • dbnh
    dbnh Posts: 194
    I have a 2200PE; the amp is common ground.
  • hearingimpared
    I was pretty sure the 2200 and 2200 PE were both common ground when in stereo mode.
  • riglehart
    If it is a common ground. That is awsome, because I can go back to the plain sda cable.
    I have a question into the NAD support site on this. I'll post what they reply.
    Jolida Tube
  • riglehart
    NAD email support isn't answering after 5 days. My audio repair guy didn't have the service manual handy when I called him to ask, but says he "thinks" it isn't a common ground. He
    confirmed that checking for continuity with an ohmmeter on the black speaker terminals would indicate common ground.
    The ohmmeter test shows them to be common. Is that fallible?
    What's the worst that could happen if I hook my 2.3TL up to this (or any) amp and it is not common ground?
    Jolida Tube
  • PolkWannabie
    PolkWannabie Posts: 2,763
    You don't want to go there ...
  • hearingimpared
    That test is sure fire. If you get zero ohms across the two speaker ground posts you have common ground. . . infallible!
  • univera
    univera Posts: 848
    For what its worth, I used an NAD 7600 receiver to power my SDA's with no problem. It uses the 2200A amp section. Not sure how much difference there is in the "A" vs. non "A," but I would think they are made in similar fashion.
    And, I did try a 2200 with an NAD pre for a short term listen. Wasn't for a long time, but nothing happened to my speakers.
    UNIVERA
    2 Channel:
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
  • ESavinon
    ESavinon Posts: 3,067
    I've used my nad 2200 pe in stereo mode with all my sdas speakers without a problem.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • rocketman
    rocketman Posts: 16
    As long as there is no reading on the volt meter between thr two ground posts there is nothing to worry about.
    rocketman
  • autoconsortium
    autoconsortium Posts: 64
    I went through this issue when I bought Lexicon 501 monoblock amplifiers. Everyone told me there were definitely not common ground. After a call to Bryston (they made this amp for lexicon, it is just a Bryston 7B with a different logo on it) they also told me they weren't common ground 'as far as they knew'. I paid mucho bucks for these and wasn't ready to just dump them on ebay in favor of common ground setup (I have Polk SDA SRS speakers). I strapped the grounds and they have been working fine for over a year with tons of use. Apparently they are common ground...or I'm just frying them over time...who knows. Sounds damn good though.
    Alex Cagann
    Polk SDA SRS
    Lexicon DC-1 preamp
    (2) Lexicon 501 monoblock amps
    Parasound CD Transport 1000
    Parasound DAC1000
    Nakamichi Dragon
    Nakamichi RX505
  • c0redumpt
    c0redumpt Posts: 35
    I'm going through this issue as we speak, as I have located a nice Krell KSA-100 amp for sale. I'm just thinking whethere this amp (a) has enough juice for my 1.2 TL's and (b) whether it indeed is a common ground amp.
    Anyone here have any opinions?
  • danger boy
    danger boy Posts: 15,722
    yeah.. email the manufacturer and they'll know 100% for sure if the amp you are looking to power you SDA's is common ground or not. I did.. and found out my Adcom is common ground.
    PolkFest 2012, who's going>?
  • Polk65
    Polk65 Posts: 1,405
    I just read this thread and to add a little more confusion...
    A NAD 2200 showed up for cheap on craigslist last year. I downloaded the online manual and after reading the sections "inverted channels" and "commutating power supply" I used the NAD webpage form mail to ask if this model is a common ground amp suitable for vintage Polk Audio SDA speakers with the interconnect cable. Three days later the reply was NO it is not a common ground amp. I followed up with another question asking which other models of this time period are not common ground and never received a reply. You don't want to see the fireworks that a non-common ground amp can cause with these.
  • fredv
    fredv Posts: 923
    Since you have the 2.3TL, worst comes to the worst, you don't get the SDA effect. There should be no damage to either the speakers or the amp even though the amp is not common ground. The pin-blade cable doesn't strap the grounds of the speaker posts, not like the blade-blade.
    -fredv-
  • riglehart
    Here's the verdict from NAD "support center". Email reply was...
    2200 = common ground
    2600 = common ground (I assume 2700 is, too, since I can't find any difference other than the THX logo)
    270 = common ground
    272 = common ground
    These are the only ones I asked about.
    Jolida Tube
  • hearingimpared
    270 = common ground
    272 = common ground
    Bugs Bunny first base
    Bugs Bunny second base
    Bugs Bunny third base
    Bugs Bunny short-stop
    Bugs Bunny right field
    Bugs Bunny center field
    Bugs Bunny left field
    Bugs Bunny pitcher
    Bugs Bunny catcher
    QUOTE Bugs Bunny vs. The Gashouse Gorillas
  • lawdogg
    lawdogg Posts: 470
    Bumping from the grave - I have a 2200 Power Envelope that I REALLY want to use with my 3.1TLs.
    • The 2200 Power Envelope manual, on p.5, warns against connecting common ground equipment but only when the channels are bridged.
    • The 2200 Power Envelope service manual, page 2, says in big capital font, "CAUTION: DO NOT CONNECT THE OUTPUT OF THIS AMPLIFIER TO ANY HEADPHONE ADAPTER, SPEAKER SWITCH, OR OTHER DEVICE THAT USES A COMMON GROUND FOR LEFT AND RIGHT CHANNELS."
    Soooo. Not sure.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • lawdogg
    lawdogg Posts: 470
    P.S. I just looked at the circuit diagram on the NAD 2200PE. Definitely not common ground. Shucks.
    <3 my 3.1TLs
  • Schurkey
    Schurkey Posts: 2,125
    What ohm reading do you get when testing left black speaker post to right black speaker post?
    I don't know of a better test than a simple ohmmeter connected across the black posts. Less than one ohm resistance, you're set. Of course, this will require the amp to be in stereo mode, bridged/balanced amps are not SDA-compatible without an isolation transformer.
    I have heard of manufacturers who don't friggin' know whether their product is common-ground or not, and give bad advice to SDA owners. Adcom, for example has told at least two folks on this forum that a certain product is common-ground when it was not.
  • lawdogg
    lawdogg Posts: 470
    Thanks for the bump in the right direction - wouldn't you know, there's continuity between grounds. So the 2200 Power Envelope IS common ground after all.
    <3 my 3.1TLs
  • Schurkey
    edited October 2017
    lawdogg wrote: »
    Measuring "continuity" is NOT ENOUGH.
    You need to read the actual resistance in ohms. 20 ohms resistance may still register as "continuity" but will not sound correct on an SDA speaker system.
    Less than ONE ohm should be sufficient.
  • lawdogg
    lawdogg Posts: 470
    Yep it measures ~0ohms across the R/L negative speaker terminals.
    <3 my 3.1TLs
