Being for the benefit of any obsessive-compulsive fans of vinyl :)
mhardy6647
This link was turned up by one of the New England vinylista and posted Somewhere Else.
I am taking the liberty of sharing it here.
http://www7a.biglobe.ne.jp/~yosh/standards_table.htm
You're welcome
You're welcome
Thanks for sharing that. I understand things much better now and will use this data to make certain each of my LP's meet the criteria before I play them again.
nooshinjohn wrote: »Thanks for sharing that. I understand things much better now and will use this data to make certain each of my LP's meet the criteria before I play them again.
You need to buy and have a selection of stylus to suit your vinyl
I take mine out rub it on an old clean cloth diaper, and put it in the tray. Hit the play button
No need to worry about grooves i let the laser find them
Boy reading the link hurt my head
I gave up on reading it since it didn't have a lot of colorful pictures in it.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I'm glad to see that the IEC98 standard, set back in 1958, for the diameter of the concentric finishing groove for 45 rpm records was set, and still stands, at 98.4mm .
I thought it had been changed to 98.6mm. I guess it's now safe for me to dig the 45's out of the box in the garage and give them some safe play time.
Sal Palooza -
I think that someone just finished the class on how to insert a table into the body of your text.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
This fellow's disc was certified by the IOC to be within these oh so important standards.
^^^^and the metric conversion was done in the title so Rick doesn't have to google it
https://youtu.be/tAXPq1co-U4
