Being for the benefit of any obsessive-compulsive fans of vinyl :)
This link was turned up by one of the New England vinylista and posted Somewhere Else.
I am taking the liberty of sharing it here.
http://www7a.biglobe.ne.jp/~yosh/standards_table.htm
You're welcome
    nooshinjohn Posts: 25,954
    Thanks for sharing that. I understand things much better now and will use this data to make certain each of my LP's meet the criteria before I play them again. :p
    txcoastal1 Posts: 13,514
    You need to buy and have a selection of stylus to suit your vinyl
    pitdogg2 Posts: 27,169
    I take mine out rub it on an old clean cloth diaper, and put it in the tray. Hit the play button :p
    No need to worry about grooves i let the laser find them
    Boy reading the link hurt my head o:)
  • erniejade
    erniejade Posts: 6,321
    I gave up on reading it since it didn't have a lot of colorful pictures in it.
  • I'm glad to see that the IEC98 standard, set back in 1958, for the diameter of the concentric finishing groove for 45 rpm records was set, and still stands, at 98.4mm .
    I thought it had been changed to 98.6mm. I guess it's now safe for me to dig the 45's out of the box in the garage and give them some safe play time.
  • I think that someone just finished the class on how to insert a table into the body of your text.
  • This fellow's disc was certified by the IOC to be within these oh so important standards.
    ^^^^and the metric conversion was done in the title so Rick doesn't have to google it :p
