Audioengine A2+ Powered Speakers-MINT
markmarc
Time to thin the herd everyone. First up is a Black pair of Audioengine A2+ computer/desktop speakers. The endless praise from the press is absolutely correct on the A2+, these mini-dynamos will blow your mind. The A2+ added in a DAC, improved the speaker terminal quality, higher quality power supply. They sat in my wife's home office, but were rarely used as she did customer service over the phone and no music was allowed. About the only time they were used was when I used Quicken to balance the checkbook. New price is $250 a pair. I'm selling for only $165 a pair including ground shipping CONUS, add $10 for Hawaii, Alaska, and Canada. Payment via PayPal.
Features:
Built-in analog power amplifiers
Dual analog audio inputs
USB audio input
Hand-finished wood cabinets
Variable audio output
Custom Kevlar woofers and silk tweeters
Power-saving idle mode
Cables included
Works with Mac or PC, no software to install
Included:
A2+ powered (left) speaker, A2+ passive (right) speaker
Speaker wire (16AWG), 2 meters (~6.5 feet)
Power supply, AC power cord
Mini-jack audio cable, 1.5 meters (~5 feet)
USB cable, 1.5 meters (~5 feet)
Microfiber speaker bags, Microfiber power supply bag, Microfiber cable bag
Specifications:
Type 2.0 powered (active) multimedia desktop speaker system
Amplifier type-Dual class AB monolithic
Power output- 60W peak power total (15W RMS / 30W peak per channel), AES
Drivers-2.75″ Kevlar woofers, 3/4” silk dome tweeters
Inputs-3.5mm stereo mini-jack, RCA, USB
Outputs-RCA variable line-out
Input voltages-110-240V 50/60Hz auto-switching
SNR->95dB (typical A-weighted)
THD+N-<0.05% at all power settings
Crosstalk--50dB
Freq. response-65Hz-22kHz ±2.0dB
Input impedance-10K ohms unbalanced
DAC-TI/Burr Brown PCM2704C
Input bit depth-up to 16 bits native
Input sample rate-up to 48KHz native
USB device class-type 1.1 or above
Protection-Output current limiting, thermal over-temperature, power on/off transient protection
WEIGHTS AND MEASURES-Dimensions (each) 6”(H) x 4”(W) x 5.25”(D)
Weight (LEFT speaker) 1.6Kg/3.55lbs
Weight (RIGHT speaker) 1.4Kg/3.15lbs
Shipping weight-4.6kg/10lbs per pair
Shipping box dims-10.5” (H) x 15” (L) x 7” (W)
Features:
USB audio input
Cables included
Included:
Specifications:
Crosstalk--50dB
Former Staff Member TONEAudio
2 Ch. System
2 Ch. System
I'll take 'em. PM sent.
If Kurt passes or changes his mind which I'm sure he won't, but just in case consider me as the default great deal.Home Theater
Hey Kurt, put me down for these when you resell them. Just wanted to let you know ahead of time before FB snakes me again.I disabled signatures.
If I do, I will. You would also get a family price.
SOLDReview Site_ (((AudioPursuit)))
2 Ch. System
