Sound Deadening Install Pics (Finally)
AustinKP
I finally got around to getting some SecondSkin Spectrum V.2 from Ant since it was such a good deal. I got 2 gallons for just under $100 shipped. According to Ant, 1 gallon is worth 40 sq ft of the Damplifier mat, so it costs approximately half of what the mat does with the same coverage/dampening.
After painting about 5-7 coats in my trunk, I'm pretty impressed with the Spectrum. It's quite thick, so it goes on very easily with a paintbrush with very little drippage/running. Just don't get too lazy, or it will run a bit, as you can see in the last picture in the spare tire well.
Let me know what you think and if you have any questions.
**EDIT** My stupid computer is still down, so here's a link to all the pictures. MANY thanks to Neo...
Pics here
-Austin
Pics here
-Austin
http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2
Alpine 9815
Post edited by AustinKP on
cardomain?
when i get my next truck i plan on using that everywhere that i can get the mat into
-Cody
Music is like candy, you have to get rid of the rappers to enjoy it -
if you want i can host some pictures for you... i have like 50 mb free.Originally posted by AustinKP
Here's after I started the 1st coat
These are after mainly finishing 2 coats. I hadn't completely gotten the rear quarter panels yet.
**EDIT** I'm installing Linux to do a dual-boot on my machine that these pictures are hosted on, so I apologize if the links don't work. Plus, even when they are working, my uploads are capped at 256Kb, so it'll be slow. Anyone else w/ more bandwidth want to host these?
-Austincats.vans.bag... -
Neo will host a few for me. Thanks for the offer swerve. I started installing Linux last night, only to find out that my 1st install CD was corrupt AFTER I wiped out my master boot partition. Now, I can't even boot into Windows, so I need to make another CD at work today.
Cody - if it were me, I'd do as much as I can w/ the Spectrum, then do the damplifier only on plastic, etc where the spectrum won't stick. This, because you get the same coverage and damping for half the price. Ant will have good advice for you. He's very friendly and VERY helpful on the phone. EXCELLENT customer service! I very highly recommend SecondSkin to anyone.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
2 Gallons SecondSkin Spectrum V.2 -
but damplifier has more mass than the spectrum, therefore making it better
Not according to Ant. I was just quoting him. One gallon (covering 40 sq ft) is as good as 40 sq ft of damplifier, making it the same coverage/damping for half the price. Now, I'm not an expert by any stretch of the imagination. You'd best talk to Ant himself, but if they provide the same effect, I'd definitely go w/ the cheaper option myself.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
im guessing he meant it would cover as much as, not it would do the same job as, otherwise you wouldnt see so much mats and a lot more liquids
you cant fake mass, damplifier has it, liquid doesnt--and mass, along with a few other factors, is what sound deadening has its basis on
No, I specifically asked because I wanted to make sure he wasn't just talking about coverage. And that gallon of stuff is pretty heavy. I don't know what the damplifier weighs, but the weight for the two gallons shipped was 24 pounds. That means they weight at least 10-11 pounds per gallon. Water is only 8 lbs/gallon.
My guess as to why mats are more common than liquids is mainly that the liquids previously were way behind, and they didn't stick as well. They have come a long way though, and their new formula is supposed to be pretty awesome.
--edit-- Mass isn't the only factor though. Otherwise you could just paint on another gallon of normal paint. Mass is important, but perhaps more importantly, the ability of the damper to convert vibrations into other forms of energy - namely low-level heat.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Yeah, austin's right, the conversion is what matters, as well as the mass. to make a long story short:
from secondskin's faq.when apllied in equal thickness our liquid damper, Spectrum is cheaper, better and lighter than any other mat ont he market, including our military grade Damplifier PRO.It's not good, very fundamentally simply not good. - geolemon
i asked ant about this yesterday and he said:
A lot of peopl dont like to wait 24 hours for the product to dry. especially car audio shops. They would rather lay th mat down then start ont he wires rather than spray, wait a day then start on the wires. with the mats you can get right in on top of the stuff.
Damplifier and Damplifier pro also have a foil heat shield which Spectrum does not. the foil can be used as a radiant barrier on the hood or engine side fire wall to reflect radiant heat away from the cabin.
WIth Damplifier there is no need to mask off the areas you dont want overspray to get on, and it is awesome for plastic, which spectrum is not..
plus, a lot of peopl dont trust the water based elastomers yet, so they feel their money is better spent on mats. We are happy to provide this option to them.
guess ill be going with spectrum for the entire floor and walls...lol
OK...pics are back up! Thanks again Neo.
-Austinhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Looks good...I had a question, but I can't remember it at the moment.1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
I'm really interested in purchasing some of this. Do you have an update on how it performs?2005 Subaru Impreza WRX
Sorry it took me a while...I've been in Missouri since last Tuesday for Thanksgiving, and just got home last night. Unfortunately, I don't yet have a sub. I guess I'm waiting for the Koda 12 to come out. I have noticed a marked difference in the volume of road and exhaust noise though. It is definitely quieter now, and I haven't even had time to finish painting it all in. I've used about 3/4 of a gallon, and have about another 3/4 to go. It'll take about 1/4 gallon per door, then I'll use the rest on my trunk. I'll give a better report when I'm completely done.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
