Anyone ever heard of this??
polrbehr
https://www.amazon.com/brennan-Brennan-B2-500Gb-Metallic/dp/B017Q9MMRG/ref=sr_1_8?s=electronics&ie=UTF8&qid=1504892497&sr=1-8&keywords=brennan+b2
http://www.thebrennan.com/
I was combing through YouTube yesterday and an ad came up for this thing from Brennan.
Normally I wait the lousy 5 seconds and click the Skip Ad button, but this one I actually watched for the whole 1:30.
Seems like a pretty decent way to access/save music, it supposedly can rip CDs directly to the internal HD, other options as well. For less than 5 bills a 500gb version can be had.
Opinions?
Opinions?
What does it do that one cannot do with a 'pute (and keep $500 smackers in one's pocket)?
PS The above is meant as a legitimate question, not snark. I..e., what is the value add over stuff (hard- and software) one might already have on hand?
I already run a Squeezebox Duet, fed from a networked PC; no complaints about it other than an occasional buffer issue (seems like my new router eliminated that).
This thing just looked intriguing, I might be tempted to do an A/B with it, but I do wish the price was a bit lower.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
The few reviews that were posted on Amazon were not favorable. I suggest you keep looking.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
From the pic of the back shows some outputs/inputs missing that are labeled. Cat 5 not available but labeled, and Coax not available but labeled.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
recoveryone wrote: »From the pic of the back shows some outputs/inputs missing that are labeled. Cat 5 not available but labeled, and Coax not available but labeled.
The USB ports are labelled "USB A", "USB B", and "USB C", but judging from their size and shape, all 3 are USB A ports.
