What is the best glue to reattach a SDA side panel?
One of the side panels on my SDA 2B TL speakers come totally loose (unglued) from the speaker today. What is the best glue for me to buy to reglue the side panel to the speaker?
Thanks.
Peter
    F1nut Posts: 51,938
    Locite Power Grab or Liquid Nails.
  • pglbook
    pglbook Posts: 2,262
    Thank you. Is it best to only put the glue around the edges of the side panel and reattach it that way? Or should I also put a litle glue on the wooden side of the speaker to which the side panel will be reattached?
    F1nut Posts: 51,938
    If it were me, I'd just put it on the cabinet and put some in the center as well.
  • pglbook
    Got it. Thanks again!
  • BlueFox
    BlueFox Posts: 15,250
    Mine warped when they came off, and the freaking cloth came off also. I tried re glueing, and placed paving blocks on the the side, but no luck. They popped off again. I believe these were made in Mexico, and they showed it. Oh well. I gave them away last year on a whole house purge Karma. Hope the new owner has more TLC than I did. :)
  • pglbook
    edited September 2017
    BlueFox wrote: »
    Sorry to hear that. Was the sound affected at all with the side panels off?
  • BlueFox
    No. As you have seen it is a very thin piece of something. I did feel that replacing it with a piece of good wood cut to that size would have been a great addition. However, I replaced them with a pair of PSB Synchrony One speakers, and eventually gave the SDAs away.
