Network Guru help needed...
If you can't change those ports that need to be opened call your ISP2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
The ports will be locked at the local level on the router. What make and model do you have? It is not a big deal to change, but the settings are specific to the device. If I know the model, I should be able to help.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
Turns out the units will no longer access the net thanks to the company that supported the functionality being out of business and McIntosh abandoning support for the unit.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Turns out that Escient technologies owned the servers and code for the MS750. They were bought out of bankruptcy by DM Holdings, and the servers set up with an independent company, contracted through DM... Sound United bought DM Holdings, and either shut down the independent company or that company folded as a result of the merger with Sound United... most likely the latter. Nobody knows who has those servers and without them, the code and the ability of my McIntosh to communicate with the web are history.
Somehow I knew it was Polk's fault!
j/k Post edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
That's inexcusable. Bad on McIntosh. That type of functionality should be protected.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
So it's a paper weight now?2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
no... just cant search titles, cover art or other things like that., which will need to be done manually.So it's a paper weight now?
