Network Guru help needed...
    txcoastal1 Posts: 13,513
    If you can't change those ports that need to be opened call your ISP
  • crashb4
    crashb4 Posts: 222
    The ports will be locked at the local level on the router. What make and model do you have? It is not a big deal to change, but the settings are specific to the device. If I know the model, I should be able to help.
    Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
    nooshinjohn Posts: 25,925
    Turns out the units will no longer access the net thanks to the company that supported the functionality being out of business and McIntosh abandoning support for the unit.
    edited August 2017
    Turns out that Escient technologies owned the servers and code for the MS750. They were bought out of bankruptcy by DM Holdings, and the servers set up with an independent company, contracted through DM... Sound United bought DM Holdings, and either shut down the independent company or that company folded as a result of the merger with Sound United... most likely the latter. Nobody knows who has those servers and without them, the code and the ability of my McIntosh to communicate with the web are history.
    Somehow I knew it was Polk's fault! :D:D j/k
    Post edited by nooshinjohn on
  • crashb4
    crashb4 Posts: 222
    That's inexcusable. Bad on McIntosh. That type of functionality should be protected.
  • mikeyb128
    mikeyb128 Posts: 2,885
    So it's a paper weight now?
    2 channel:
    Theater:
    mikeyb128 wrote: »
    no... just cant search titles, cover art or other things like that., which will need to be done manually.
