FS: Outlaw Audio M200 Monoblock $100 obo
Airplay355
I picked this up used when I bought an SVS sub. The previous owner was using it to power the sub. I just replaced it with a Crown amp so I don't need it anymore. While it did make the SVS useable, especially for music, it wasn't enough for HT. I also hooked it up to my LsiC and it sounded fine there as well. I couldn't tell any difference between the monoblock and a single channel from the Model 5000 I also have so I don't really have a reason to keep it.
Specifications:
● Power Output: 200 Watts RMS into 8 Ohms, 300
Watts RMS into 4 Ohms; 20 Hz - 20 kHz
● MFR: Not Specified
● S/N: 100 dB
● THD: < 0.05% at Full Output into 8 Ohms
● Inputs: One RCA Unbalanced
● Input Impedance: 41 kOhms
● Size: 1.75" H x 17" W x 11.5" D
● Weight: 18 Pounds
● MSRP: $299 USA
It's got some cosmetic wear on the top from other gear being stacked on it but the face is fine and all lights (well, the one light) works. Inside the boards are pristine and the amp sounds great, it just wasn't enough for the SVS (obviously). The only problem I have is that the RCA input seems to be a little loose and will cut out if the cable isn't pulled to the right a bit. I bet it's an easy fix for someone who wants to fiddle with it or you can do what I did and just use it as is. Just full disclosure
If you buy it and when it arrives you think it's not working, it's because of this issue. I can take pics if you want but didn't want to bother if there wasn't any interest.
Price: $100 obo + shipping from 29609.
Specifications:
● S/N: 100 dB
● Weight: 18 Pounds
● MSRP: $299 USA
Bump
May also be interested in trades -
I said OBO. haha No one needs a mono? It's just sitting in my closet.
I may be interested. Gotta see how the new to me Onkyo AVR treats the center channel.
Sounds good!
Sent you a PM.AVR: DENON X4000
FRONT L/R: ARX A3RX-C
CENTER: ARX A2RX-C
SURROUND L/R: ARX A3
SUBWOOFER: PSA-XV15
SERVER: UNRAID 15TB
MEDIA PLAYERS: DUNE SMART SERIES D1
HDTV: VIZIO M601D-A3R -
Are you sure? I didn't get it
Edit: NVM, found it on my wall. I sent you a reply. -
Also sent you a PM!
SOLD
