Audio Technica Lp-120 Lube
stainless0steel2
in Electronics
Has anyone ever tried lubricating the spindle bearing on one of these? After two years I'm sure it needs it.
I just can't find anywhere on the interweb that explains how...
The Night is Dark and Full of Terrors
I doubt it needs lubed, ever. Is there any mention of it in the owners manual?Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
Yea there's no mention of it.The Night is Dark and Full of Terrors
I've never used any on my 120 which i've had for 5 years.
Play the gamble!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
What? AT? Heeeeey... waaaaaaait a minute... I thought you were running a Technics! Tricked me good.
Maybe head over to KAB to see how it's done on the 1200? IIRC, on Technics models it's as simple as pulling the platter off, and adding a drop or two to the spindle, or through some holes? Can't remember correctly, apparently.
Have you had a look under the platter yet?
Don't forget to add a couple of drops to the Stylus. Helps keep it cool through more complex record passages.
for people stumbling in, don't really do that last partPost edited by msg onI disabled signatures. -
I know my vintage Technics you lube it when new, then every 2000 hrs of playing. That would be like every 20 years....lol.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
indeed -- most "modern" (1970 and beyond) consumer/massmarket tts don't require much attention vis-a-vis bearing lubrication AFAIK.
Is it doing something wrong?
Probably nothing more cowbell won't fix.I disabled signatures.
This weekend I need to open it up again and figure out a ground looping problem. I figured since I'm in there might as well lube her up.The Night is Dark and Full of Terrors
^^^^In my best Beavis ---ha ha haha haha he said......
Now that I'm home, it sure seems like it'll be easy to get to. Looks like there's a secondary platter.
I bought some tt lubricant on the Amazon a week ago so I'm definitely going to do everything I can to try.
The Night is Dark and Full of Terrors -
-- are those DIP switches I espy there at about 8 o'clock (with respect to the spindle)? what do those do?
mhardy6647 wrote: »-- are those DIP switches I espy there at about 8 o'clock (with respect to the spindle)? what do those do?
not dip switches some kinda # stamp
gotcha
Interesting, Brian - so a cover beneath the platter? Like Craig said, looks like 2k hours on the Technics tables anyway. Maybe if there's no spec on it for your table it's supposed to be maintenance free?
Yea that's the voltage selector
There's no mention of lubricating any where in the manual. I'm still going to open it up to look.
If I see a bearing I'll hit it. If not we'll...The Night is Dark and Full of Terrors -
Dip the whole tt in a bath of 10W-30 and leave it submerged for 1/2 hour. Remove it and allow to drip dry. That'll get all accessible bearings nice and juicy.
Alternatively, maybe fit a Zerk to the bearing; make it easier next time.
Go all the way and install a jewel bearing.The Night is Dark and Full of Terrors
That's unfortunate...nothing to lube. All permanently sealed.
He REALLY wants to lube something! Lol2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I say drill a few holes and fill 'er up.
And then post up on AK, SteveHoffman, and VinylEngine about how important it is for all owners to do this mod.
I also like how Brian's got the soldering station and the Cardas ready to go.I disabled signatures. -
Well I'm still working on the ground looping issue. I figured I'd take a second look at the phonoectomy (that's a real word I just made up) I did awhile back. Everything looks ok as far as the tt goes.The Night is Dark and Full of Terrors
There sure is alot of stuff in that TT2 channel:
Theater:
ahh, I didn't realize you were having a grounding issue.
Nice soldering station, btw. I have the same one on recommendation of senior member, and it really makes soldering a lot easier. Before, I might as well have been using a curling iron and a bar of chocolate.
The Phonoectomy - did you simplify the output path, removing the onboard phono pre and going straight to the RCA terminals?I disabled signatures. -
Weller is the only way to go. I love this thing!
Yea I tore out the phono preamp and installed two female rca jacks and a terminal for the ground. Before it was all hardwired to the motherboard. It wasn't a night and day difference. But it was definitely worth it.The Night is Dark and Full of Terrors -
Yup.
No such thing as "permanently sealed"; those words merely represent a challenge.
LOL doc
Please don't encourage sledge and pry bar2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
