Audio Technica Lp-120 Lube
Has anyone ever tried lubricating the spindle bearing on one of these? After two years I'm sure it needs it.
I just can't find anywhere on the interweb that explains how...
The Night is Dark and Full of Terrors
  • I doubt it needs lubed, ever. Is there any mention of it in the owners manual?
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • Yea there's no mention of it.
  • mrbiron
    mrbiron Posts: 5,721
    I've never used any on my 120 which i've had for 5 years.
    Play the gamble!
    msg Posts: 10,452
    edited August 2017
    What? AT? Heeeeey... waaaaaaait a minute... I thought you were running a Technics! Tricked me good.
    Maybe head over to KAB to see how it's done on the 1200? IIRC, on Technics models it's as simple as pulling the platter off, and adding a drop or two to the spindle, or through some holes? Can't remember correctly, apparently.
    Have you had a look under the platter yet?
    Don't forget to add a couple of drops to the Stylus. Helps keep it cool through more complex record passages.
    for people stumbling in, don't really do that last part
    Post edited by msg on
  • motorhead43026
    motorhead43026 Posts: 4,017
    edited August 2017
    I know my vintage Technics you lube it when new, then every 2000 hrs of playing. That would be like every 20 years....lol.
    mhardy6647 Posts: 35,151
    indeed -- most "modern" (1970 and beyond) consumer/massmarket tts don't require much attention vis-a-vis bearing lubrication AFAIK.
    Is it doing something wrong?
    msg Posts: 10,452
    Probably nothing more cowbell won't fix.
  • This weekend I need to open it up again and figure out a ground looping problem. I figured since I'm in there might as well lube her up.
    txcoastal1 Posts: 13,514
    ^^^^In my best Beavis ---ha ha haha haha he said...... B)
  • msg wrote: »
    Now that I'm home, it sure seems like it'll be easy to get to. Looks like there's a secondary platter.
    I bought some tt lubricant on the Amazon a week ago so I'm definitely going to do everything I can to try.
    -- are those DIP switches I espy there at about 8 o'clock (with respect to the spindle)? what do those do? :/
    msg Posts: 10,452
    Maybe a Voltz-tage selector?
    msg wrote: »
    Yes probably
    stand corrected
    msg Posts: 10,452
    Interesting, Brian - so a cover beneath the platter? Like Craig said, looks like 2k hours on the Technics tables anyway. Maybe if there's no spec on it for your table it's supposed to be maintenance free?
  • Yea that's the voltage selector
    There's no mention of lubricating any where in the manual. I'm still going to open it up to look.
    If I see a bearing I'll hit it. If not we'll...
    edited August 2017
    Dip the whole tt in a bath of 10W-30 and leave it submerged for 1/2 hour. Remove it and allow to drip dry. That'll get all accessible bearings nice and juicy.
    Alternatively, maybe fit a Zerk to the bearing; make it easier next time.
  • Go all the way and install a jewel bearing.
  • That's unfortunate...nothing to lube. All permanently sealed.
    msg Posts: 10,452
    LOL wtf Brian!
  • mikeyb128
    mikeyb128 Posts: 2,885
    He REALLY wants to lube something! Lol
    2 channel:
    Theater:
    msg Posts: 10,452
    edited August 2017
    I say drill a few holes and fill 'er up.
    And then post up on AK, SteveHoffman, and VinylEngine about how important it is for all owners to do this mod.
    I also like how Brian's got the soldering station and the Cardas ready to go.
  • Well I'm still working on the ground looping issue. I figured I'd take a second look at the phonoectomy (that's a real word I just made up) I did awhile back. Everything looks ok as far as the tt goes.
  • mikeyb128
    There sure is alot of stuff in that TT
    2 channel:
    Theater:
    msg Posts: 10,452
    ahh, I didn't realize you were having a grounding issue.
    Nice soldering station, btw. I have the same one on recommendation of senior member, and it really makes soldering a lot easier. Before, I might as well have been using a curling iron and a bar of chocolate.
    The Phonoectomy - did you simplify the output path, removing the onboard phono pre and going straight to the RCA terminals?
  • Weller is the only way to go. I love this thing!
    Yea I tore out the phono preamp and installed two female rca jacks and a terminal for the ground. Before it was all hardwired to the motherboard. It wasn't a night and day difference. But it was definitely worth it.
    msg wrote: »
    Yup.
    No such thing as "permanently sealed"; those words merely represent a challenge.
    LOL doc
    Please don't encourage sledge and pry bar
    txcoastal1 wrote: »
    LOL doc
