Does anyone have a "My Pillow"
Opinions, are they worth it?
  • Wife uses one, we (she) has tried many a pillow over the years, she loves it! Well worth the cost.
  • A good friend of mine swears by his "My Pillow."
    On the other hand, my wife did some research on "The National Sleep Foundation," from which My Pillow's inventor claims to have received an award. She thinks it is a sham organization.
    My thought: If you're having trouble sleeping with whatever pillow you are now using, give it a try. Like every other product of the sort, it probably works for some and not for others.
  • Derf
    I use one and like it. The pillow is filled with a bunch of chopped up foam pieces so you can arrange it anyway you like to make the pillow fluffy or flat.
    Integrated Amp: Marantz PM-10
    Speakers: Usher MD2
    Subwoofer: Rythmik F15HP
    DAC: North Star Design Supremo
    Streaming Source: AURALiC Aries Mini
    SACD Player: Marantz SA8004
    Power Source: PS Audio PP3 on dedicated 20amp circuit
  • My wife seems to like hers but I don't care for mine.
  • whats a matter u?
    'Does anyone have-a my pillow'
  • Really like mine...has helped my constant neck pain when sleeping...
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • When ordering, pay attention to the part where they ask . . . something like your size and weight. Cuz there are 4 different types of filling they use.
    I recommend that if you're on the boarder, go 1 size down, JMHO
    I like my, My Pillows!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Unknown
    edited August 2017
  • Unknown
    edited August 2017
  • Damnit, you guys. Now I want one. I've always struggled with pillows. This better be the one!
    I hope it makes me happy like this.
  • Had 2 and didn't care for them
    Garage | Polk Monitor 5B's
  • Unknown
    edited August 2017
  • teekay0007
    edited August 2017
    mdaudioguy wrote: »
    The reason Mike Lindell is that happy? The last count I heard, he'd sold 25 Million My Pillows!
    I've always slept poorly. Very poorly! Got a My Pillow and right from the start, I was getting to sleep faster and sleeping more soundly with less nighttime or early-morning awakening. The pillow also doesn't seem to get as warm or hot and I don't need to flip it during the night. It gives great neck support and has greatly reduced my neck stiffness. And, as you might have guessed.......I absolutely Love It! <3<3<3
    In their favor, they do let you try it out for a generous number of nights with a full return guarantee. I don't recall how long the trial is (3 months? Maybe 4 months over Christmas, since it might sit under the tree, etc. for a month?) since I knew I was keeping mine right away.
    It also comes with a ten year warranty! I don't know how great this is or if it's a pro-rated kind of thing...ie. fails after eight years, they give you a 20% credit, etc. I really never read it. The pillows are machine washable and dryable.
    Proper sizing (firmness/fill level) is a big part of whether you'll be happy with it or not. I first got a Green size (a little more stuffed and right for most dudes) as advised by their website. After I'd used it for a while (couple of weeks?) and had washed it, I decided it was probably a little firm. I took it into one of the local My Pillow stores and exchanged it, without incident, for a White size (less firm and recommended for some dudes and most women). Since then, I am WAY happy!!
    I also got a White size one for my sister and a Yellow size one for my 80+ year-old mother and they both love them! <3
    Now, I take My Pillow along whenever I'm going to be sleeping away from my own bed!
    Lastly, if you decide to try one, make sure you get the "Premium" ones and not the "Standard" ones. The Premiums have a gusset edge on them, a small vertical panel all the way around, whereas the Standard ones simply come to a tapered edge all the way around. The gusset helps with better support. They used to sell the Standard ones at Bed Bath and Beyond stores. In the My Pillow stores, they only sell the Premium ones.
    Also, while you're at it, I'd say, get your pillow cases from them too. I'm glad I did. My other cases would not have worked well, size-wise. Their cases fit just right and wash and wear really well.
  • mdaudioguy wrote: »
    Lastly, if you decide to try one, make sure you get the "Premium" ones and not the "Standard" ones. The Premiums have a gusset edge on them, a small vertical panel all the way around, whereas the Standard ones simply come to a tapered edge all the way around. The gusset helps with better support. They used to sell the Standard ones at Bed Bath and Beyond stores. They only have Premium ones in the My Pillow stores.
  • teekay0007
    edited August 2017
    https://www.youtube.com/watch?v=tRqhH7V7VOQ
    The ones shown in this video are the Standard ones - No, no, no! Only get the Premium ones!
  • I will order a couple. My neck is afu and my sleep is even worse. Thanks folks!
  • They work just fine...and the part where Mike says designed it to be machine washable and dryable is true too...One of my cats puked on mine and it washed up like new!..Damned cat!...LOL!..
  • These are better
  • Imma get one of those too!
  • gce
    I think we should do the blind test on these.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • voltz
    edited August 2017
    gce wrote: »
    but it if slips off the bed I'll break my neck finding it again!
    I find I like the flattest pillow these days and not the big fluffy one that puts a crook in my neck.
  • Why would I have your pillow?
  • Is it resistant to being bitten?
  • I got the "bamboo pillow" I like it. It's a comfortable pillow but I'm young and don't have neck pain, a pillows a pillow to me.
    Shut up Cody
  • gce
    Don't you get splinters? :|
    Anaheim Hills CA,
  • voltz wrote: »
    That is exactly how I was. I like to sleep on my back and with the big fluffy pillows my head was jacked up too high and my neck would hurt the entire following day. But, with the flat pillows, my neck got no support and I'd again have pain in the neck and shoulders. Even if I bunched up the flat pillow under my neck, it would flatten out during the night. With My Pillow, I can bunch it up a little bit under my neck and have it flatter under my head and it holds its shape through the night and gives that all-important support to the C-spine area.
    I saw one of their commercials on TV last night and the trial period they offer is 60 days, not three months, like I had thought and mentioned in a previous post.
  • Love mine. Miss it when I travel even when some hotels give three or four different pillows on the bed none are as comfortable to me.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • we have a few My Pillows in the house and they are good. Not my choice of pillow but a good product. I own and love the Snuggle Pedic and often you can pick one up in King size for around 80 bucks. Normally 197 a pop. I use 2 of them and like them much more then the My Pillow. I am real picky though and have beat my body up bad through the years. A little more money then the MP but a lot more pillow too.
  • Hey Johnny, haven't seen you around lately. Good to hear from you, hope all is well.
