Confused about RTI-A series speakers?
I have a setup of CSI A6, RTI A5 and RTI A3's. I love the set but am having trouble with 2 certain speakers. My back left RTI A3 keeps having the Mid-Woofer blow and distort. I have replaced it twice and it keeps happening. Also, my CSI A6 keeps losing tweeter and mids. I have replaced all parts including crossover, tweeter and mid-woofers and the speaker keeps going bad. I do not play the system to excessive volume as I have a two family and tenants above me. I built my system for quality sound more so than loudness. I have the RTI A5's and RTI A3' powered off an Emotiva LPA-1 and the CSI A6 powered by an Emotiva XPA-100.
    F1nut Posts: 52,165
    You either have some settings out of whack or your amps are sending DC to those speakers.
  • rooftop59
    rooftop59 Posts: 8,120
    I do have to agree that something sounds really amiss. Although some on here don't like the emotiva-rti combo, it should provide plenty of current and you should not be blowing speakers at moderate (or even pretty darn loud) volume.
    Unfortunately, I do not know enough to be of much help. But more info about your setup might allow others (like @F1nut) to be of service...
    Game Room 5.1.4:
    Bedroom 2.1
  • mrloren
    mrloren Posts: 2,474
    Yes I agree sum ting wrong. Speakers should not be blowing like that. I would have the amps checked to make sure they are not passing extra voltage to the speakers. I would also make sure that the speaker cables are not getting chewed on or picking up AC current some place
  • incloud
    incloud Posts: 93
    Thanks guys, the folks at Polk are insisting that I am overpowering the center speaker with 250 watts from the XPA-100 and the CSI A6 only rated to 200 watts. I'm not a stereophile by any means but I did a lot of research prior to purchasing equipment. I was told on several occasions that more power meant more headroom and less chance of distortion. Polk has always been really good about replacements and shipping without question. I have all the original packaging but the guy I spoke with yesterday says I have to ship back separate parts at my cost now to have new ones sent out. I'm getting of this and just want to enjoy my system. Any and all suggestions are welcome. For the record,I do not and rarely have ever pushed my system to extreme levels. Sound quality is far more appealing to me than loudness. I mainly watch movies with Plex Media Server to a Roku Streaming Stick. My PC has i7-4770k with 32GB 2400 MHZ Ram GTX960 2GB Nvidia card and SSD OS along Raid0 8TB for media.
  • incloud
    incloud Posts: 93
    No chewing as I have no pets.
    txcoastal1 Posts: 13,519
    edited August 2017
    Are you running all speaker full range?
    Ever play music all channels driven?
    What receiver do you have?
  • incloud
    incloud Posts: 93
    No, I have them all crossed over at 80hz with an SVS PB-2000 Powered Sub.
    OK....yes very strange
  • rpf65
    rpf65 Posts: 2,127
    Sounds like you need to get those amps serviced by a qualified service center.
    It would be understandable if you blew speakers once, that may very well be the speaker. Multiple times, at reasonable volumes, you have something else going on, assuming everything is wired correctly and all of your settings are correct.
    I ran RTI A5's, CSI A4, FXI A6's, and RTI A3's off an entry level Yamaha, usually in the 60 to 70 dB range, and never had any issues.
  • incloud
    incloud Posts: 93
    Once I get the speakers fixed or replaced I'm going to try and run them all straight off the Yamaha with no external Amps and see how the performance is. If the sound is good, I'll just sell the amps. I don't need or use all the power I have. Just got carried away with the build I guess.
  • mrloren
    incloud wrote: »
    considering your amps may be the problem, I'll take them off your hands free of charge.
    Seriously I'll even pay for shipping for them defective amps.
    Something in the mix is not right. Are you running bare wire into the post on amps and speakers? Maybe try banana plugs if you are.
  • incloud
    incloud Posts: 93
    I'm using banana plugs and Emotiva cables
    F1nut Posts: 52,165
    Check your calibration settings.
  • mrloren
    incloud wrote: »
    Ok so no wires shorting out then. I would have the amps checked out by a qualified service center. It's hard to blow a speaker. Only ones I have blown was in my car stereo days
