RTA-12c's with RD0194’s - amp suggestions?
I picked these old girls up the other night, gorgeous shape, no issues. Dated 1984. But they make my old Sony receiver choke. Any suggestions for (inexpensive) power amps? I really don't want to spend more than $500. Suggestions?
These will be used for stereo music and L/R in my Atmos+vintage Polk setup (frankenpolk center, Monitor 7B surrounds, Monitor 4B's surround back, 4 RC60i's in ceiling for Atmos height channels) all driven by Marantz SR6011. Planning on pre-out to a larger amp for the RTI-12’s for L/R... what should I be shopping for...?
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • FestYboy
    FestYboy Posts: 3,861
    I have to say I'm very impressed with my NAD... A strong amp from them will easily stay in budget, and easily drive you RTAs. My 11Ts are currently hooked up and going anywhere past 10 o'clock volume knob gets obnoxious quickly. The same should hold true for your 12s.
  • JayMX
    JayMX Posts: 459
    Which NAD model are you running?
  • pkquat
    pkquat Posts: 748
    edited August 2017
    I am not specifically familiar with these, and their efficiency. It all depends on your final goal and price range, then you will get more useful answers.. IMO you can't really go wrong sonically with Parasound for their used prices. They will be better than the AVR. NAD is good product as well.
    I have some 11t's. They also have two drivers. I do notice a bit of bass fall off with very good 100-125wpc SS amps. 250 wpc has no issues. That said the 11t's loose some detail at those levels. IMO a good 125-150wpc amp should be fine. 100 wpc may also do just fine.
  • Emlyn
    Emlyn Posts: 4,827
    Parasound HCA-1500A. Should be able to find one under $500.
  • Nightfall
    Nightfall Posts: 10,083
    I liked my B&K on those speakers. 350 watts $225
    afterburnt wrote: »
    Village Idiot of Club Polk
  • FestYboy
    JayMX wrote: »
    CE320BEE
  • CH46E
    CH46E Posts: 3,595
    edited August 2017
    I have both a Parasound 2250 v2 and a NAD 906 bridged for 90×2 with one channel of the 3 or 6 depending on how you configure it.
    I like the sound of the NAD better. Wont go as loud as i like but love the sound on my RTA 12B.
    Id look for a NAD.
    Post edited by CH46E on
  • CH46E
    CH46E Posts: 3,595
    edited August 2017
    If you want a reciever from about the same time frame take a look for a Pioneer A717 or A878. I heard one on a pair of Vandersteens. I liked it very much. And they look pretty cool toppless. The pioneer that is. Lol
    My bad, i did not see ypu already had a pre htr.
    Like others said. I would loom alfor a NAD. I love mine. Right nownit runs my 11t in the living room.
  • JayMX
    JayMX Posts: 459
    Picked up a B&K ST1430 on eBay for $145 tonight. Hopefully it will have enough umph. Supposed to be 185Wpc into 4ohms. Can't wait til it shows up! Anyone familiar with it? I can find the manual for the 1430 Series II online but the series 1 manuals seem to be nonexistent...
