Where can you buy whitewall tires?
nooshinjohn
Picked up a former show winning 1975 Buick Riviera today. The car includes the famous Buick "rally" style road wheels, but I will be dammed if I can locate brand new 235-70-15 whitewall tires to put on them. Seems BFG Meeks raised white letter in that size, but they would not be appropriate on a car big enough to double as a flagship for Chester Nimitz.
I think these might be in the same isle as black paint. Any he would be awesome.
Coker tire.
Coker tire.
Must be the tire size that may be hanging you up John. I just seen a old pimp mobile going down the road the other day and commented to my son about the wide white wall tires. -
WHAT A RIDE! Nice. Real nice. So it was stored in someone's horse barn or is that just a prop for the pic?
Google brought me
https://www.dbtires.com/why_choose.html -
Post edited by motorhead43026 onPatriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
Just not a shop stocked with black paint
Neat-o.
(FWIW) I like all the Rivieras -- but I think I like the original design and the behemoth boat-tailed models best of all (no offense!).
I prefer the original too. This one is pretty rare though as it has buckets and floor mounted shifter. I believe only 1200 cars got that option.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Luigi's Casa Della Tires... I believe he's still in Radiator Springs.
nooshinjohn wrote: »I prefer the original too. This one is pretty rare though as it has buckets and floor mounted shifter. I believe only 1200 cars got that option.
That is cool!
Those rally wheels on the old Buicks were some of the best looking wheels ever made imho. I prefer the 60's body styling though.HT SYSTEM-
lsi 9's -
That car needs hydraulics so it can bounce up and down while cruising the boulevard.
Three 20 amp circuits. -
5000 pounds doesn't bounce. It crushes anything stupid enough to get in the way.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Cool car. Have any of the previous owners done engine work? Those mid-70's cars are pretty crippled by the emissions control attempts from the factory. My dad has a 76 Olds Gutless that couldn't get out of it's own way.
Once the car gets home, I will be going over it thoroughly. 1975 is the cutoff year in CA for smog inspections, so I will be deciding on whether or not to keep it 100% stock or do some mods. If I mod it the first thing that will go is all the smog crap that chokes things up. 455 cubic inches of big-block power should be able to do better than 205 horses.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
You won't get much more from it. The engine is designed low compression to begin with.
Btw nice car, I have a real affection for these 2 door land yachts.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
motorhead43026 wrote: »You won't get much more from it. The engine is designed low compression to begin with.
I think it is possible to coax out 350hp from it... not as much as it should have, but better than it already has.
That's one of the reasons I hate mid 70's up, all the emissions crap, lower horsepower. A 455 from earlier years, combined with those turbo 400 tranny's were screamers. The Olds 425's could lay rubber for a block. Sleepers....that put some stock Camaro's to shame.HT SYSTEM-
lsi 9's -
If you're pulling the block for any reason, yank the pistons, and swap out the heads for factory appearance irons. Thats the only way you'll see the 350hp mark. Factory heads won't flow unless you port the carp out of them. The carb and intake will do the job for that power level.
I'm a fan of factory appearance... That way you can still show it as it was intended, and also have the power it deserves (have cake, will eat). -
My dad told me he used to paint his tires so...
"I think these might be in the same isle as black paint. "
Built like a body by Fisher!
aww, c'mon -- that lead sled is wicked cool.
It probably wouldn't fit in my garage, though...
And those 400 tranny's were bulletproof! It's amazing how far trans. technology has come. Riding in my friends Hellcat last night I was blown away at how fast it shifted. I don't know if it's humanly possible to manually shift as fast as that car did last night. -
Wait?! "Trannys"?! "Drag racing"!? -- what kind of forum is this, anyway?
(ahem)
mhardy6647 wrote: »Wait?! "Trannys"?! "Drag racing"!? -- what kind of forum is this, anyway?
(ahem)
The good kind daddio. Put your keys in the bowl. -
I dunno guys, John's around L.A., where do all the Hispanics get theirs ? Miami corner the market or what ?
Hard to believe in Cali, classic car heaven, you can't find whitewalls. HT SYSTEM-
lsi 9's -
It's not. That's why in most cases manu-matic tranny's are quicker than standard tranny's.
Dual clutch auto-manuals are very cool. Always was a stick guy, until my last 2 cars with dual clutch auto-manuals w/paddle shifters. Best of both world's (in the real world) and I don't really miss the 3rd pedal at all because the dual clutch auto (in this case DSG) is lightening fast when shifting, especially to pull off a fast pass. I can change gear faster than it takes to push in a clutch. Basically snap of the finger.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Loaded up and ready to come home...
nifty.
speaking of NDSWRK -- check out this guy's tale of woe with a "pre-owned" 2002 Dodge.
http://audiokarma.org/forums/index.php?threads/my-lemon.783769
