This place is For the Walking Dead!
megasat16
Some says Dead, Some says Not Dead! I say this place is for the walking dead!
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Well ok, not dead at all.
Good luck, hopefully better results than last one.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Oddly, I just saw George Romero get on the bus.
Well, that's the problem you see? Some says Dead. Some says not Dead! What else can it be? 50-50 Dead?
OK, I am just trolling for good fun.
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I'm 79 still enjoying the Polk 2.3 stock SAD's along with a Carver C-2 Pre Amp and a M-1.0t Amp, life is great!! Not dead.. young is boredom and dead... get a life..Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
Warren,
No one would thought you are 79 from your pic posted. I had a whole stack of Carver gears at one time and they sure rocks the house! They are also great for the heirloom pieces for the young gen!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Shut up, Dan. -
It's only mostly dead...
impressive Warren!
Dibs on the 2.3's
Rock on Warren!
https://m.youtube.com/watch?v=J34esa_aJxc
