The Clamp, a world-class turntable clamp
    treitz3 Posts: 20,366
    Anybody still in touch with him? Has he straightened out his life?
  • motorstereo
    motorstereo Posts: 2,428
    I hope he's straightened out his life as it was a mess when I last talked to him in 2012. Some of it had to with the clamp and violated patent rights from what Joe was telling me. He seemed like a very smart guy and I bet he was a lot of fun to hang out with before the demons took over.
    F1nut Posts: 52,406
    He never had a patent because he never applied for one.
    Skip, multiple reasons which we don't need to rehash.
    It has been more than some time since he has been gone. Everybody deserves a second chance.
    Any reason he should not?
    F1nut Posts: 52,406
    That is not going to happen.
  • Dawgfish
    Dawgfish Posts: 2,554
    treitz3 wrote: »
    Looks like the same exact thing with lite differences on the outside. Sure was a lot of "fluff" in the description of it though. I wonder why he photo shopped Joe's clamp on the top pic...that's just...weird.
    Inspiredsports, yes. Cost was the number one brick wall for Joe and trying a second run at it.
    That was the first version of the Simply Physics clamp and as you can see, its pretty much "The Clamp." The only difference is it doesn't have the knurled surface on the upper knob like the clamp. The surface of the knob is smooth. Other than that it's a blatant copy. How do I know? I bought the first version of the Simply Physics clamp off Audiogon for $45 before I found out it was a blatant copy of The Clamp. Still have it, it works quite well.
    SCompRacer Posts: 9,404
    edited August 2017
  • agfrost
    agfrost Posts: 2,497
    Quick phone camera shot of The Clamp in its new home.
    Thanks, Greg!
    Jay
    agfrost wrote: »
    Nice! I like to yell Micro Seiki when I do my kata...lol
  • agfrost
    I tell you, there is next to zero info about this turntable online. They must have made about 5 total. It's been berry, berry good to me though.
    Jay
  • Unknown
    edited August 2017
    edited August 2017
    agfrost wrote: »
    They go for big bucks. Very well built. Veneer over pressboard.
    This is underside of Yamaha YP-D10 I had. Yours would look similar.
    WOW Rich I have never seen that. I've used the pin point oil applicator but never knew they had a grease.
    It's good stuff!
  • vmaxer
    vmaxer Posts: 5,124
    SCompRacer wrote: »
    It's good stuff!
    @lightman1 has been using it for years, however a bit different application.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    txcoastal1 Posts: 13,520
    vmaxer wrote: »
    SCompRacer wrote: »
    It's good stuff!
    So you been camping with him too?
  • Dawgfish
    agfrost wrote: »
    Thanks, Greg!
    Beautiful deck! Is that a Stanton 881 cart?
  • vmaxer
    vmaxer Posts: 5,124
    txcoastal1 wrote: »
    vmaxer wrote: »
    SCompRacer wrote: »
    It's good stuff!
    Nope, "word of mouth"
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • agfrost
    Dawgfish wrote: »
    Thanks! A local Craiglist transaction that my wife still rues (I went for the Micro Seiki and came back with it plus several hundred LPs!)
    Good eye--the cart is a Stanton 881S. Stylus was collapsed when I acquired it (actually torn off IIRC), so I replaced it with a JICO shibata. I've been quite happy with it.
    Jay
  • schwarcw
    schwarcw Posts: 7,360
    Dawgfish wrote: »
    treitz3 wrote: »
    The big difference in the Version 2 vs the Clamp is the lip on side/bottom edge is much thinner on the Version 2 vs the Clamp. It's more difficult to hold the edge of the Version 2 while tightening.
    In fact if there would be any improvement in Joe's Clamp, it would be to make his side/bottom edge a little thicker as well, making it easier to grasp with the thumb and finger(s) to tighten firmly to flatten a warped record. That was the primary driver for Joe to design the Clamp with the shims. The Clamp uses it's underside lip to push the outer rim of the record against the platter, coupling the record to the platter. Rich likens it to adding torque to the sound! LOL! It works! No doubt about it, there is a noticeable improvement in the sonics.
    Carl
  • Emlyn
    Emlyn Posts: 4,919
    I started using mine on a Technics SL-1200 MK II a few months ago and was really surprised at the improvement in sound. It took what was a fairly sloppy sounding table, that to me was good for just blasting hard rock, and greatly improved the clarity, control and noise floor.
    Pretty good for a gadget designed 30+ years ago. But it was more expensive than the turntable itself when I bought it new.
  • kharp1
    kharp1 Posts: 3,453
    agfrost wrote: »
    Thanks, Greg!
    I'm jealous. Nice looking table.
  • Dawgfish
    agfrost wrote: »
    Dawgfish wrote: »
    That's awesome! Sounds like the wife made a great score! I've yet to try a Stanton. A 681, 881, and 981 are on my list to try. Congrats again on the beautiful setup and score on the clamp.
  • inspiredsports
    I've not dug that deep into my stash yet but believe I have 1 or 2 Stanton 681 EEE MKIII's here and probably at least 1 never-to-touch-vinyl replacement stylus. Will check
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    I have cartridge serial # L9287 in good condition (trading for $80-$100 + S&H on eBay) and a new stylus lists at $120 (these actually sell for about $55 + S&H). This cartridge has a great stylus installed, and will modify my comment the replacement I have never touched vinyl. I inspected with my loupe and can see I tested the new one, so it's probably seen an album side or two.
    NAD SS rigs w/mods
    GIK panels
  • Dawgfish
    Oh wow! Awesome! I am definitely interested if you would like to part ways with one. Thanks!
  • inspiredsports
    inspiredsports Posts: 5,502
    edited August 2017
    I've always felt these are amazing for the price and worth well more than their retail selling prices.
    Let's make this set of 1 cartridge with 2 great stylii (??) $125 Shipped to some happy Polk vinyl junkie. (or IM me if we are close)
    NAD SS rigs w/mods
    GIK panels
  • Dawgfish
    Deal! PM sent!
  • inspiredsports
    I believe you will love this little jewel !!
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    Hmm, not seeing the IM . . .
    NAD SS rigs w/mods
    GIK panels
