What do use to stream music to your Hi-Fi ??
....and why ??
Looking to upgrade the $50 Gramofon I'm currently using for Spotify. Must support Spotify and Tidal. (I may step up to Tidal's lossless at some point) Remember it must be easy to set up as I'm as dumb as a bag of hammers. :)
Bill
Because I am The Pumpkinking
«13
    treitz3 Posts: 18,333
    Bluesound Node 2 w/Musical Fidelity Tri-Vista DAC.
    Why? Good question. Probably price. 5 bills for the Bluesound Node 2. Very easy to set up. Lossless is worth it IMO but then again, so is an outboard DAC that doesn't support MDQ.
    tonyb Posts: 32,906
    Sonos for the simplicity, but it won't do higher than cd quality. If you want to go higher formats, Bluesound is another cheap alternative.
    Cheaper than cheap is chromecast, but not sure about their Spotify capabilities.
  • pumpkinman
    pumpkinman Posts: 9,520
    tonyb wrote: »
    I just found out that Sonos now does support lossless but will not support the MQA available from Tidal.
  • jeremymarcinko
    If you have a decent DAC I recommend the Chromecast "Audio" for an effortless streaming experience from most apps and servers.
  • pumpkinman
    I do not own a DAC.
    I'm leaning towards the Bluesound Node.
  • BlueFox
    BlueFox Posts: 15,251
    Lumin S1. It is an all in one solution; file player, streamer, and DAC. Does Tidal, and now supports MQA. You can't get simpler than the S1, and it sounds great.
    ^^^ He keeps harping about this^^^
    To date? Have not heard it. Contender? Yes. Heard it? No.
    SCompRacer Posts: 8,352
    edited August 2017
    I use an older Signature Sonore Music Server with Deux power supply. Basically a mini PC with custom power supplies (one for PC, one for USB card) and power filters for hard drive. It's fanless, no noise. Playback, no noise. SOtM-PCIe USB output card and SOtM drive power filter. I updated it with a small SSD card for the Linux op system and stuck a 6TB drive in it. I can also point it to an external NAS when the time comes. Controlled through a variety of third party aps with cell phone or tablets.
    Still using my DIY Dual Mono Buffalo III DAC with Sonore USB to I2S module. Discrete balanced output (no op amps). Sounds fantastic.
    If I didn't have that, I'd go for a Sonore micro or ultra Rendu. IIRC they added Spotify this year and it does Tidal. bikerboy just upgraded from the micro to ultraRendu. IIRC Carl (schwarcw) has the microRendu.
    http://www.sonore.us/microRendu.html
    A thread by Carl.
    http://forum.polkaudio.com/discussion/172912/sonore-microrendu-wuhoo/p2
    txcoastal1 Posts: 13,132
    Simaudio 780D Dac and streamer
  • gce
    gce Posts: 2,158
    I just picked up a Marantz NA8005 for dirt cheap and it sounds great!
    Anaheim Hills CA,
  • afterburnt
    afterburnt Posts: 7,892
    treitz3 wrote: »
    Tom, there are a few folks here that have them including me. I think it's a great piece, worth every penny and then some.
    Anybody compared it to the BS N2?
    I ask because I hate wasting money ad Mr. Pumpkin would want to know..
    That's what I am afraid of Skip. Spending more money for the same thing I have heard ever since streaming came about along the Hi-Fi world. There is always something missing....maybe I honed in on it when I brought it home for a direct comparison.
    Sub par sound, while at the same time. "close to CD quality".
    My version of "CD quality" and others apparently differs.....vastly.
  • mikeyb128
    mikeyb128 Posts: 2,885
    That auralic Aries mini is a steal, I have one hooked up to my Bryson BDA3, and I also brought it to my local hifi shop and hooked it up to several DACs. It's one heck of a performer, that you would have to spend a lot more to best. I have only spent a short time with its onboard DAC, which I found to be ok. Not exactly a fair comparison though, when being compared to something 8 times the price.
    2 channel:
    Theater:
  • Mikey081057
    Mikey081057 Posts: 7,127
    BlueSound Node2 into Marantz SA8004's DAC.
    Listen to Tidal HiFi an Masters.
    Sounds nice.
    Garage | Polk Monitor 5B's
  • pumpkinman
    Thanks for everyone's input
    Bill
  • rooftop59
    rooftop59 Posts: 7,981
    Dude, @pumpkinman, DACs are pretty darn cheap now for some pretty nice ones (for those of us who play in the real world lol). I would seriously think about a Chromecast audio and something like a peachtree DACit: http://www.ebay.com/itm/Peachtree-Audio-DACiT-D-A-Converter-DAC-iT-/332340306078?hash=item4d6106a09e:g:TIUAAOSwmZdZjg9z and you would be set! Can beat that for under 300 bones!
    BUT, to use a chromecast you need a laptop, tablet, or smartphone that you can cast from. Its very simple, but you can't used it like some of the more advanced streamers.
    Game Room 5.1.4:
    Bedroom 2.1
  • recoveryone
    Still using Squeezebox Touches throughout the house, 6 still going strong. The technology is dated now, but its been the standard to meet for about a decade. If not for Logitech abandoning the project and simply improving on a front runner from its price point it would still be the go to setup.
    Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Optimus LS30's Rear Surrounds Optimus LS30's Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Fluance Signature Tower Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX103 Squeezebox Touch Polkaudio R50 Towers Polkaudio CS 10 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Polk audio RTi 6 fronts, Rears Dayton B652 Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
  • Joey_V
    Joey_V Posts: 8,520
    Bluesound node2
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
    nooshinjohn Posts: 25,100
    Just picked up a McIntosh MS750 music server. I have only played with a few functions and listened to some Johnny Cash on it. This is amazing. I will be loading all my cds to it over the coming months and running it exclusively when not using the turntable.
  • rooftop59
    A budget would really help, these suggestions are all over the map lol...
    Game Room 5.1.4:
    Bedroom 2.1
  • pumpkinman
    Wife picked me up a Sonos. I'm still a vinyl freak but streaming is fun
  • jeremymarcinko
    Enjoy!
    Clipdat Posts: 12,605
    I read this and thought "Nice! Sounds like a perfect unit!"
    Went to Google it and saw the $12k pricetag. Immediately closed browser window. :/
    BlueFox wrote: »
  • Nightfall
    Nightfall Posts: 10,071
    Clipdat wrote: »
    BlueFox wrote: »
    Check out the Auralic Aries Mini.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall
    DSkip wrote: »
    Nightfall wrote: »
    Clipdat wrote: »
    BlueFox wrote: »
    Find a used one since they are out of production. Don't get the bluesound unit as I don't know anyone who thought the sound quality was close to the AURALiC unit.
    Permanently?
    afterburnt wrote: »
  • Nightfall
    edited December 2017
    Does that mean updates on their iOS software are done and chances of an Android version are dead?
    afterburnt wrote: »
  • Nightfall
    Thanks Derek.
    afterburnt wrote: »
