Mold on LS50's
eviled72
I removed my 10 year old LS 50's from storage and they have small mold spots on the rubber surrounding the woofers. I don't want to damage the speakers in order to get rid of the spots. Can I leave it alone or will it spread and get worse? They sound great and have no other damage. I just don't want to do more harm than good. Any help?
Post edited by eviled72 on
There is a product used in hospitals, etc. for removing mold, but first I would try Windex. Spray it on a soft 100% cotton cloth, then wipe gently in a circular motion. If that doesn't work I'll get the name of the other stuff for you.Political Correctness'.........defined
President of Club Polk -
I'd give hydrogen peroxide a shot... Very mild disinfectant... that won't attack the rubber...
Be careful of drips "bleaching" out fabrics in the neighborhood...
H2O2 is the stuff blondes are made of...
More later,
Tour...
Vox Copuli
Thanks for the info. I'll try hydrogen peroxide and then windex.
