Say you just won a beauty contest
and you just had $11,148.50 to build the best 2 channel system you could,
how would you go? If new, please state the discounted price if available. If used,
please state the price of what is currently available as well. No media yet.
Dedicated listening room size 17X13X10 with no WAF to worry about.
  • mrbiron
    mrbiron Posts: 5,721
    With the handle "RedNedTugent", i guess i had you all wrong.
    Bikini photo's or it didn't happen!
    pitdogg2 Posts: 27,047
    well 11K would be just about enough for my speakers....
  • cvc
    cvc Posts: 65
    What a ridiculous post..
  • voltz
    voltz Posts: 5,384
    Ushers mini X's + Vincent SA T7 preamp + Vincent SP T700 Tube mono blocks
    with $$$ left over B)
  • voltz
    voltz Posts: 5,384
    go buy some good cables and call it a day!
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited July 2017
    I do like the look of those ushers...
    I'm glad you are still digging the Vincent.
    Didn't think I'd have to put someone on the ignore list. :|
    msg Posts: 10,452
    mrbiron wrote: »
    There are no 'reactions' for this that match my sentiment. I just feel... I don't know man... unsettled.
    Forget audio. That money'd be better spent on 2hrs with Charlie Sheen in Vegas between 2am - 4am on a Saturday morning. You did say no WAF requirement.
  • motorhead43026
    motorhead43026 Posts: 4,010
    ^^yep, hookers and coke.
    – Kevin Alfred Strom
  • voltz
    voltz Posts: 5,384
    edited July 2017
    Red Get yourself up to Skip's house in October and then swing by Marvins place to hear several awesome ushers and see them in person... I'm going to bring my Ushers to Skips house then also!
  • [Deleted User]
    ^^^^ mentioned the option to the Wifey and she told me to "off" and left w/
    her mother. :# I'm parsing this into it's a pretty good idea.
    cvc wrote: »
    I'd say it's awesome. It tripped your trigger to post.
    :p:p:p:p:p
  • [Deleted User]
    As a point of reference, what speakers do you have?
    Maybe I should aim higher...
    "bully for you, chilly for me"
  • kharp1
    kharp1 Posts: 3,453
    voltz wrote: »
    I think I recognize those speakers.
    No no my speakers are nowhere near that. I'm saying the 11k for me would be spent on some legacy speakers. Like say Legacy whispers or something. If we are dreaming dream BIG!!! ;)
  • [Deleted User]
    Here we go. Thanks for the input.
  • MrBuhl
    MrBuhl Posts: 2,419
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • [Deleted User]
    edited August 2017
    I've stared at the legacy more than I few times myself in Stereophile truth be know.
    Nice, is that DNA-500 20 amp? I should have added the caveat that 80lb per piece
    is about the upper limit. I'd want to keep it for as long as I could!
  • tratliff
    tratliff Posts: 1,790
    Those Legacys are really nice. Trust me I have a pair but mine are in a Rosewood finish. And to pair them with the McCormack would be an outstanding combination.
    When I was on the hunt for amps I was interested in a pair of DNA-750's. I was going to purchase them used and then ship them over to SMC (Steve McCormack) for complete upgrades. I actually talked to Steve himself about doing the work. Great organization he has and was very helpful in understanding what to expect. But when everything was considered I decided to move in a different direction with amps. Still would like to give them a run though.
    But those speakers need a good sized room. I am pushing it with my room. I could use about another 6-8 feet from front to back.
    I have seen and listened to those speakers powered with 30wpc tube amps and they were fine but when you pair them with SS 250+wpc they really shine. Soundstage, clarity, definition, scale, weight.... They just come alive.
  • erniejade
    erniejade Posts: 6,321
    Last time I was in a beauty contest I won second prize in a beauty contest collected 10$
    erniejade wrote: »
    that was 5$ tooo much >:)
  • MrBuhl
    MrBuhl Posts: 2,419
    edited August 2017
    Yes I think so, I think you'd need dedicated 20a for what she pulls. There is always the cheaper and lighter DNA-1 Deluxe route if you can find one, mine (not deluxe) has ample juice and you could get one used for around $1200 I bet. Save enough money for a nice CDP and still have tons of power!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • [Deleted User]
    this is great info. Thanks! I miss the bottom end when rocking out w/ my
    two way bookies. This is one of the things I'm trying to overcome. However, there is
    so much stuff in the "studio" that I am practically near field some of the time in my
    listening. (so the bookies are great for that)
    Check on the may have to do electrical for that amp...
  • motorhead43026
    edited August 2017
  • tratliff
    If you interested in Legacy speakers and need them for a smaller location you should check these out.
    http://legacyaudio.com/products/view/calibre/
    tonyb Posts: 33,072
    Hmm....Legacy's and McCormack, match up well. I would suggest a Joule pre or VAC though over the CJ.
    As far as the Legacy's go, I have the Focus 20/20's and they leave me wanting for nothing. You can find them used under 3k. The newer improved versions are icing on the cake though so if a good deal came up on those, jump.
    DNA-1 Deluxe....uh, yeah....you'd be hard pressed to find it's limits since Legacy's are so efficient. DNA-500 is a monster and with efficient speakers it wouldn't break a sweat. Ya need some tubes in there, and a Joule pre is just the ticket, no sloppy or syrupy lower bass like some tube gear can contribute.
    Plenty of avenues to go down, I just wouldn't blow the whole wad on audio. Save some, for when life throws you those unexpected curve balls.
  • [Deleted User]
    "Plenty of avenues to go down, I just wouldn't blow the whole wad on audio. Save some, for when life throws you those unexpected curve balls."
    like when the wife says we are going to Hawaii in January?
  • deucekazoo
    deucekazoo Posts: 146
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • mrbiron
    I think more info is needed.
    Aside from the pre, amp, and speakers, what else do you need/want.
    CD Player?
    DAC?
    Turntable?
    Phono?
    Power Conditioning?
  • [Deleted User]
    edited August 2017
    Now they are rolling in!
    I've never had any luck with tubes.
    Dunno why.
    deucekazoo wrote: »
    mrbiron wrote: »
    CD Player?
    DAC? I
    Turntable?
    Phono?
    Power Conditioning?
    Well that is part of the fun. Give up the disc spinners altogether? Live w/ what I have
    AFA turntable, universal, CD players...
    Power conditioning would depend on the amp and maybe the transport IMHO.
    I would like to try it on the player side me thinks...
