Speaker replacements
I'm needing to replace the four 6.5" speakers in my suburban, right focus is on the front speakers for now. They are paired with tweeters that are functioning, but I'm thinking I'll skip over those and go with 2 way or 3 ways in place of the woofers.
I'm not thinking of spending much, there are some boss brands that are cheap on ebay, so price wise I'm thinking like less than 50 a pair. I just need something that works and sound decent for a good price.
Many thanks in advance!!!
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
  • codycatalist
    codycatalist Posts: 2,661
    The component sound is different than coaxial that's for sure.
    https://www.amazon.com/Polk-Audio-DB651-Certified-Speakers/dp/B000P0PF9G/ref=pd_lpo_vtph_107_bs_lp_tr_t_2?_encoding=UTF8&psc=1&refRID=77M7Y0CF83PSKQZXCR6M
    These are a little over $50 a pair but not much. Sound great too, had them in 3 different cars before switching to the MM line.
    https://www.amazon.com/Renegade-RX6-2C-6-5-Inch-Component-System/dp/B0045SRLE6
    Don't know how those sound but a pair of 6.5 components for $35, I know Renegade is a subdivision of Rockford.
  • deucekazoo
    deucekazoo Posts: 146
    I don't know if I would switch over to coax on the front. You might not like the sound because the high frequencies get muffled by your legs/seats. That is why they are putting tweeters up high on most cars these days. But if I was you and wanted to go cheap, I would look at craigslist for someone selling their system. You can pick up real good speakers at good prices.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    Thanks for all the replies, yeah i dont necessarily want to go coaxial if possible bc i have excellent experience with components systems.
    I even thought of leaving the tweeters and getting some wof ets but I did that once and the tweeters started buzzing soon after... not sure what happened, I figured the woofers messed up the crossover point but idk how that would happen.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • deucekazoo
    You might have removed the cap that blocks the low frequencies to the tweeters. A lot of the OEM manufacturers put that cap on the back of the woofers and then run the signal wires to the tweeters. If I were you I would just keep the stock tweeters as long as they work, get your new woofers and then just make sure you keep the cap (if you can find it from the original speakers) or add a cap to the signal wire to the tweeters to block the lower frequencies. You should be good to go.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
  • Mr. Sharpe
    Sounds good, the caps are actually attached to the rear of the tweeter on these:) so going a new set of woofers will work just fine. Thanks so much for all the replies!!!
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    deucekazoo wrote: »
    I can't remember where I saw it are full range signals sent to the front woofers in this vehicle, since the cap is located on the tweeters?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • deucekazoo
    Yes they should be, the woofers should naturally roll off on the high frequencies.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
  • Mr. Sharpe
    Okay sweet, I ordered some coaxial drivers I had already planned on using in the back, I may try in the front, then later will probably get some nicer woofers to go up front.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    I got the coax speakers and put one in, come to fine out the drivers side tweeter is blown:( very sad bc the speakers alone sound pretty bad. I think once I get some nice component speakers to go up front it'll work out nicely.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Unknown
    edited August 2017
  • Mr. Sharpe
    It's definitely not bose. But thank you. The install of anything should be really easy, this vehicle has some little mounting rings I just drilled small holes for the screws and just popped it in speaker and all... the tweeter install will be different as the hole is larger than the stock tweeter, what I'll end up doing is cutting holes in a secondary board of some kind that will sit over this hole with tweeters in there... shouldn't be any problems:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    Yea I've been doing more research on replacing the sub but the two brands I've seen that made replacements (kicker and memphis) their pricing is insane like wow.... so seeing as how you can do a amp crossover bypass, I may just dish out closer on to $100 or more for a lot nicer front door speakers. I'm not going nuts spending $300++ on a subwoofer, no need.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Unknown
    edited August 2017
  • Mr. Sharpe
    I already got some cheap pyramid brand coax's that I'm trying in the front, turns out two tweeters is too harsh on the ears, but I was planning on putting them in the back anyway, that's why I'm saying just as long as I can get the front speakers sounding good I'm happy. It doesn't have to rattle my brain
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • I got the lower end polk separates and have been really pleased. First the polk stuff tends to be more efficient than most of the others out there which means you don't need a lot of amp to drive them. You can still get some last year's model of 6 1/2 with a one inch dome for a little less than $120 bucks. If you get the current version they are around $140-160. I paired them with a sub but they mak decent bass if you don't want to crank it way up:
    latest version:
    https://www.amazon.com/Polk-Audio-DB6502-Component-Motorcycle/dp/B01N0KKB7W/ref=sr_1_16?s=electronics&ie=UTF8&qid=1538883599&sr=1-16&keywords=Polk+Audio+6+1/2+component+car+speakers
    previous version:
    https://www.amazon.com/Polk-Audio-DB6501-6-5-Inch-Component/dp/B000P0R6LQ?psc=1&SubscriptionId=AKIAIKBZ7IH7LXTW3ARA&&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B000P0R6LQ&tag=wwwbookcompar-20&ascsubtag=5bb95d06eba0c90834e460d4
  • Mr. Sharpe
    Hi thanks for the input but we hit a deer and it did 5 grand worth of damage, I have a different vehicle now. I did however end up putting some pyle coaxial speakers in the doors and it did improve the sound:-)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    Oops didn’t realize I already said that
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    la2vegas wrote: »
    How did you cook the deer?
    Yep grilled, real good :D
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    Quite expensive hahaha
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
