Noob's intro to HiFi forum lingo
FestYboy
Ok, I've been around audio (pro) for a while, but since joining here, I've come to realize that there's a new language I need to learn.
If someone would be so kind, could you define or break down the more common short hand, acronyms, or slang so that I might follow the threads with better understanding? Thanks so much.
It would be easier if you told us what words/slang you are having trouble with.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Mostly the acronyms... Like oppo
I'm guilty of using alot of slang and acronyms in the Festiva forum and having to define or break them down for noobs there or for those over seas who use different words for the same part. -
Oh, I saw that word being slung around like it was a component, not company. Ok, so that answers that.
I figured IC can be either interconnect or integrated circuit depending on context. TT is turn table. Are there others that y'all can think of?
I figured this thread might help other noobs like me so if a good list can be compiled, it might be stickie worthy. -
I always thought BM was bowel movement. Bass management, knock me over with a feather...
Yes. The English language allows that flexibility. That is one reason why it is a difficult second language.
Three 20 amp circuits. -
IC - Interconnect
SC - Speaker cable
PC - Either power cable or over sensitivity
AVR - Audio video receiver
PR - Passive radiator
MW - Midwoofer
TT - Turntable
Cart - Turntable cartridge
DAC - Digital to analog converter
JBH - Jesse's beautiful hairafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
@mikeyb128 that's a considerable list!
But @Nightfall, you've got the idea I was after.
And maybe I should add to the list: nicknames... things like Klipsch horns... I know within the context, the writer is referring to a specific model or series, but when I see that all I can picture is the actual component, and Google is almost worthless for getting the intended image.
I'm a total noob, but dang it!, I want to learn. -
This is the most important one.
JBH - Jesse's beautiful hairPolitical Correctness'.........defined
President of Club Polk -
Sitting in a pool of bass.....
You'll know it when you feel it. -
SET single ended triode
DHT direct heated triode
I don't think there's anything else worth knowing, actually.
7 Hz and you might find yourself sitting in a pool of something else entirely
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
What's your address? -
WALLET - the thing that grows inversely proportionally^5 to the amount of time and people you get to know here.I disabled signatures.
mhardy6647 wrote: »SET single ended triode
You are correct Sir!!! Lol -
1600 Pennsylvania Ave.
Hurry, bring lawyers guns and money.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Curtain blower's = Italian Bookies!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Focus gentlemen, focus....
No need to bring my Celestions into this @DSkip. I was a good boy and swapped them for 11Ts as soon as I got them.
BYSB - blows your sack back (credit: tonyb)
This is one you have to experience to fully understand. Otherwise, it's like trying to describe a color. Plus, that conversation just gets weird, talking about the specifics of sack blowing, ripple effect, sustain, etc.
You'll know it when it happens, or so I hear. I've just taken to BYSB Emulation with a couple of big fans with proper toe-in, but I don't think it's the same.I disabled signatures. -
@msg, I imagine age and frequency of usage of said sack has effect on the aforementioned sustain and ripple....?
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
He did come off as a man's man.
Met @Lightstar1 and @EndersShadow last Saturday. Good guys, (may be a stretch for the notorious @lightman1 )Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
No need, my hair is perfect.Political Correctness'.........defined
Home made organic protein gel
A few random ones...
SS - Solid State (transistors, not tubes)
OTL - Output TransformerLess - a specific type of tube amp
Caps - Capacitors
OB - Open Baffle, a type of speaker that is typically without an enclosure
DSP - Digital Signal Processing
DMM - Digital Multi Meter
SW - Sub Woofer
MIT - Musical Interface Technology - very high end cables
OFC - Oxygen Free Copper
FR - Frequency Response
FWIW - For What Its Worth
BTW - By The Way
IIRC - If I Recall Correctly
IMHO - In My Honest Opinion
IIWM - If It Were Me
WWJD - What Would Jesse Do
"Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn -
YMMV? The first M is what gets me? Usually there's an R in that position.
DAC = digital analog converter
Pre/pro = preamp processor -
https://youtu.be/9DryqGwNyfU
Critic Steve Simels said (approvingly) of this album when it was released: "It'll kill your house plants." High praise indeed.
aooooooooooooooooooooooooooooooooooooooo
