Noob's intro to HiFi forum lingo
Ok, I've been around audio (pro) for a while, but since joining here, I've come to realize that there's a new language I need to learn.
If someone would be so kind, could you define or break down the more common short hand, acronyms, or slang so that I might follow the threads with better understanding? Thanks so much.
  • cfrizzcfrizz Posts: 13,420
    It would be easier if you told us what words/slang you are having trouble with.
    Marantz AV-7705 PrePro, Classé 5 ch. 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  • FestYboyFestYboy Posts: 3,860
    Mostly the acronyms... Like oppo
    I'm guilty of using alot of slang and acronyms in the Festiva forum and having to define or break them down for noobs there or for those over seas who use different words for the same part.
  • treitz3treitz3 Posts: 14,617
    Hehe....Oppo is a company.
    https://www.oppodigital.com/
    In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
    ~ The best way to enjoy digital music reproduction is to never listen to good analogue reproduction ~
    ~ Not all things that can be measured can be heard and not all things heard can be measured ~
    ~ When the law ends, tyranny begins ~
    Oh, I saw that word being slung around like it was a component, not company. Ok, so that answers that.
    I figured IC can be either interconnect or integrated circuit depending on context. TT is turn table. Are there others that y'all can think of?
    I figured this thread might help other noobs like me so if a good list can be compiled, it might be stickie worthy.
  • BlueFoxBlueFox Posts: 14,137
    FestYboy wrote: »
    Yes. The English language allows that flexibility. That is one reason why it is a difficult second language.
    Lumin X1 file player
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
  • mikeyb128mikeyb128 Posts: 2,887
    2 channel:
    Theater:
    @mikeyb128 that's a considerable list!
    But @Nightfall, you've got the idea I was after.
    And maybe I should add to the list: nicknames... things like Klipsch horns... I know within the context, the writer is referring to a specific model or series, but when I see that all I can picture is the actual component, and Google is almost worthless for getting the intended image.
    I'm a total noob, but dang it!, I want to learn.
  • F1nutF1nut Posts: 45,413
    This is the most important one. B)
    JBH - Jesse's beautiful hair
  • lightman1lightman1 Posts: 10,760
    Sitting in a pool of bass..... ;)
    You'll know it when you feel it.
  • mhardy6647mhardy6647 Posts: 26,944
    SET single ended triode
    DHT direct heated triode
    I don't think there's anything else worth knowing, actually.
    lightman1 wrote: »
    7 Hz and you might find yourself sitting in a pool of something else entirely ;)
  • vmaxervmaxer Posts: 4,851
    lightman1 wrote: »
    @lightman1 = IGNORE.......
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    vmaxer wrote: »
    lightman1 wrote: »
    What's your address?
    You are correct Sir!!! Lol
  • voltzvoltz Posts: 5,423
    Curtain blower's = Italian Bookies!
    Focus gentlemen, focus.... :p
    No need to bring my Celestions into this @DSkip. I was a good boy and swapped them for 11Ts as soon as I got them.
  • msgmsg Posts: 6,261
    BYSB - blows your sack back (credit: tonyb)
    This is one you have to experience to fully understand. Otherwise, it's like trying to describe a color. Plus, that conversation just gets weird, talking about the specifics of sack blowing, ripple effect, sustain, etc.
    You'll know it when it happens, or so I hear. I've just taken to BYSB Emulation with a couple of big fans with proper toe-in, but I don't think it's the same.
    la2vegas wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    1600 Pennsylvania Ave.
    Hurry, bring lawyers guns and money. B)
    What, no strippers? You got to bring those.
    Some things go without saying, @lightman1 knows to always have strippers tag along.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    la2vegas wrote: »
    vmaxer wrote: »
    la2vegas wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    He did come off as a man's man. ;)
    Met @Lightstar1 and @EndersShadow last Saturday. Good guys, (may be a stretch for the notorious @lightman1 ) >:)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • daddyjtdaddyjt Posts: 1,494
    A few random ones...
    SS - Solid State (transistors, not tubes)
    OTL - Output TransformerLess - a specific type of tube amp
    Caps - Capacitors
    OB - Open Baffle, a type of speaker that is typically without an enclosure
    DSP - Digital Signal Processing
    DMM - Digital Multi Meter
    SW - Sub Woofer
    MIT - Musical Interface Technology - very high end cables
    OFC - Oxygen Free Copper
    FR - Frequency Response
    FWIW - For What Its Worth
    BTW - By The Way
    IIRC - If I Recall Correctly
    IMHO - In My Honest Opinion
    IIWM - If It Were Me
    WWJD - What Would Jesse Do
    YMMV? The first M is what gets me? Usually there's an R in that position.
    DAC = digital analog converter
    Pre/pro = preamp processor
    nbrowser wrote: »
    Would like to buy some hair product?
    No need, my hair is perfect.
    Critic Steve Simels said (approvingly) of this album when it was released: "It'll kill your house plants." High praise indeed.
    aooooooooooooooooooooooooooooooooooooooo
Howdy, Stranger!
