need good COAX cable.... $ to pay
I need a COAX cable to go between a Chord Chordette DAC and a Primaluna CD player. Any opinions on a decently priced cable? This is a digital cable, right, so the sound shouldn't be chaged with a decent cable, right?
Any recommendations?
  • halo
    halo Posts: 5,616
    Creative Cable Concepts "Green Hornet" worked very well for me in my setup between my Sonos & my DAC.
  • i have heard the debate on coaxial cables changing the sound.. i am not 100% sure if they do or not.. i know i had 2 brands of coax at one time but cant remember if i heard a difference or not.. been a while since i have used one.
    personally im liking my audio quest cables so i would probably get a forest or cinnamon coaxial cable from them..
    Cambridge Azur 651A
    Polk LSi M703
    Sonos Connect
  • motorhead43026
    motorhead43026 Posts: 4,009
    Wireworld starlight 7, good cable on the cheap.
    Signal cable silver resolution is no slouch either for the money.
    – Kevin Alfred Strom
  • agfrost
    agfrost Posts: 2,468
    Rivercable.com has a couple of good, relatively inexpensive options.
    Jay
  • [Deleted User]
    [Deleted User] Posts: 10,716
    I haven't tried it but, stereophile liked this
    Canare DigiFlex Gold model RCAPOO3F
  • kevhed72
    kevhed72 Posts: 5,140
    They matter. Try to find the fabled Black Cat Velour on the used market. It will expand your sonic horizons beyond time and space my friend.
  • [Deleted User]
    edited July 2017
    ^^^ how do you like your blackcat @dromunds ?
  • kevhed72
    I like it over the AQ VDM 3 I was running for a long time. I know cables don't matter but the bass seems a bit tighter and everything a bit more focused. I think it stays for awhile....
  • dromunds
    dromunds Posts: 10,125
    I can't say that I have a great lot to compare it to, but the Black Cat is the best of what I've tried. Very nice cable.
