SDA SRS
    F1nut Posts: 52,008
    Ok, the general rule of thumb is not to go past half volume as amps tend to start clipping, although less obvious with tube amps.
  • Billcooley
    Billcooley Posts: 20
    Think I found the problem,the ground wire on interconnect cable inside right speaker was not soldered well and was loose SDA is great . Thanks for all the help.
    PS listening to a little Floyd as I type.
